Introduction: Margaret Mead House in Minecraft
This is an instruction on how to build the Margaret Mead House from Doylestown Pa in Minecraft 1.13 or above.
Step 1: To Begin...
Start with an open area.
Step 2: Basic Layer
Start with a single layer using blue concrete, quartz stairs, bricks, and brick stairs.
Step 3: First Story Window
Begin with the first story window in the formation in the picture using white stained glass, blue concrete and quartz stairs.
Step 4: Door Way & Second Story Window
Raise the door way using blue concrete and use quartz blocks and stairs to create a small roof. Then continue the main window up to the second story.
Step 5: Finishing the Front Wall
Finish off the window and raise the blue, concrete wall up in a pointed way, shown in the picture.
Step 6: Begin the Roof
Use stone brick blocks and stairs to build the roof.
Step 7: Second Window and Roof
Use the same blocks from the first window to creat the second window like the formation in the picture. Then use stone brick stairs to build the second roof.
Step 8: Connecting the Roofs
Expand both roofs until they connect at each layer.
Step 9: Interior of Windows
Use dark oak planks to surround the windows on the inside. This will make it as if there is an interior. You can also add end rods to add some light and make it look as if there are candles in the windows.
Step 10: Finishing Touches
Use more end rods as pillars at the end of the porch.
Add anything that you prefer and enjoy.
