Introduction: Marshmellow Shooter
How to make a Marshmellow shooter.
Step 1: Supplies
Gather supplies
3' - 1/2" PVC pipe
2 - 1/2" PVC Elbow
2 - 1/2" PVC Tee
2 - 1/2" PVC slip cap
Step 2: Cut PVC to Size
Cut PVC Pipe to the following sized
1 - 7" piece
1- 5" piece
5- 4" pieces
Step 3: 5" Into Elbow
Add the 5" piece into one of the Elbows.
This will be where you insert the marshmellow.
Step 4: 4" Piece Into Elbow
On the open side of the elbow from step 3, insert a 4" piece of PVC
Step 5: 4" Piece Into PVC Tee
Insert the open end of the 4" pieces of PVC pipe from step 4 into one of the PVC tees.
Step 6: 4" Piece Into PVC Tee
Insert a 4" piece of PVC pipe into the left side of the tee used in step 5. Should be on the same side as the place you will insert the marshmellow.
Step 7: Elbow Pointed Down
Attach a PVC elbow to the 4" piece of pipe used in step 6. Elbow open end should be pointed down.
Step 8: 4" Piece Into Elbow
Insert a 4" piece of PVC pipe into the open side of the elbow used in step 7.
Step 9: Cap Creates Back Handle
Add a PVC cap onto the 4" piece of pipe used in step 8. This has created the back handle.
Step 10: 4" Into Tee
Insert a 4" piece of PVC into the remaining open end of the tee used in the previous steps.
Step 11: Add Tee and Repeat Previous Steps to Create Front Handle.
Add the remaining PVC tee to the 4" PVC pipe used in the previous step. Then repeat the process of the previous steps to create the front handle. Then insert the 7" piece to the open end of the PVC tee to complete the Marshmellow Shooter.
