Masican's Skateboard
Introduction: Masican's Skateboard
My name is Marsican, this is the first skateboard I built, hope you like it!
Teacher Notes
Step 1: Step 1: Build the Skateboard Board
The size is as shown in the figure above. Build arectangle of 400*200, and use the spline curve to establish the intersection of the arc and the two long sides of the rectangle
Figure 1: demo building a skateboard size base sketch
Step 2: Step 2: Set Up the Sweep Path and Stretch the Plate
The radian on both sides of the skateboard is established in the ZY plane, and the first hypotenuse is used to sweep out the entity, and the rectangular entity in the middle is connected and merged to form the plate. After the completion, click the side transition line (4), inverted round corner
Figure 2: create radian sweeping path on both sides of the skateboard surface
Figure 3: schematic diagram of rounded corners on the side
Step 3: Step 3: Set Up Plate Bottom Wheel Frame
Build a 70*60 rectangle and stretch it into arectangle with a height of 5. Similarly, make a middle plane on both sides, use arc as sweep path, and make a circle at the start of sweep, sweep it into an inclined cylinder. Similarly, make two wheel support parts and merge them into the slide plate
Figure 4: complete drawing of combined plate bottom
wheel frame
Step 4: Step 4: Set Up the Wheel Bracket
Build a 50*60*30 cube with a diameter of 15mm through hole on the wide side and return to the sketch. Build the wheel frame on both sides with a 15mm round stretching solid. Make a sketch on the round surface and make a circle with a diameter of 8mm
Figure 5: three steps of setting up the wheel bracket
Step 5: Step5:making Wheels
Within a diameter of 50 mm, outside diameter is 25 of concentric circles, stretching into the cylinder, return to the sketch, at the center of the circle to create a within 15 mm outside diameter of 8 mm diameter of concentric circles, in the two circles to draw a pie, characteristics of tensile become the hub, the great circle around 50 mm fillet, and establish a tangent plane in cylindrical flank, groove is used to establish the entity, the circular array pattern, establishing entities.
Figure 6: wheel contour construction and pattern
beautification
Step 6: Step 6: Install
According to the actual movement relationship to install, complete
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Fix It Contest
      Fix It Contest
    2 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    2 months ago
    I like the way you did the wheels :)
    marsican
    marsican
    Reply 2 months ago
    Thank you very much!
