Mastering the Fold of a Fitted Sheet
Introduction: Mastering the Fold of a Fitted Sheet
Are you tired of bunching up that fitted sheet? Are you frustrated with the corners? Worry no more! In this tutorial, you will learn how to fold a fitted sheet. The size of your fitted sheet may vary, but these directions will still apply. This tutorial is a step-by-step way of learning not only to organize your sheets but also eliminate wasted space.
Supplies:
  • a fitted sheet (any size)
Teacher Notes
Step 1: Take Your Fitted Sheet and Turn It Inside Out.
(refer to the picture in step one for steps 1-3)
Step 2: Rotate the Sheet So That the Long Sides Are Parallel to the Ground.
Step 3: Stick Your Left Hand Into One Corner and Your Right Hand Into the Other Corner.
Step 4: Next, Bring Both Hands to Meet.
Step 5: With Your Hands Still Inside the Corners, Take Your Right Hand Over Your Left Folding the Corner Over the Other.
Step 6: Place the Right Hand Where Your Left Hand Was and Then Use Your Left Hand to Tuck in the Loose Fabric on the Side.
Step 7: Rotate the Sheet to the Left.
Step 8: Keep Your Left Hand in the Left Corner and Push the Fabric Into the Other Corner With Your Right. Just Like You Did in Step 3.
Step 9: Place Each Hand in a Corner.
Step 10: Lay the Sheet on the Ground or a Flat Surface.
Step 11: Fold Sheet From the Folded Edge Toward You in Three Sections.
Step 12: Flip the Long Folded Sheet Over.
Step 13: Then Fold Lengthwise From Left to Right in Three Sections. Viola! You Did It!
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    Penolopy Bulnick
    Penolopy Bulnick
    2 months ago
    Very nice job! These can be such a pain :P
