Mechanical Pencil Gun #3
Introduction: Mechanical Pencil Gun #3
[a more powerful version of https://www.instructables.com/id/E46CF748H5EQZJIW1W/]
make a small pea shooter like gun for free or cheap with a Bic mechanical pencil and a strong rubber band.
a well made pea shooter can shoot bb's quite a ways. my best is around 20 ft with a sting.
and don't be stupid and hit someone in the eye with this. its small but powerful. don't blame me if you do something stupid with it. (thats my disclaimer.)
i'm also currently working on a larger version of this with a steel tube and bungie cords. i might post that later if it works out.
Step 1: Get the Stuff
Thinks you'll need:
1 Bic mechanical pencil,
1 strong rubber band,
1 pair of scissors
Step 2: Disassemble the Pencil
First things first. take off the white cap of the pencil by pulling on it.
next, remove the eraser and cut off the black lead grabber at the tip of the pencil. the shaft should then come out of the pencil.
Step 3: Make the Cuts
get your scissors handy.
1st (pics 1, 2, and 3)
first take the barrel and cut off the thinner end w/the scissors. make sure not to pinch the barrel closed.
once the end is off take one blade of the scissors and carve out the inside of the barrel where you cut to make sure you don't have any pieces sticking out or have any leftover of the thin part.
2nd.(pic 4)
take the shaft and cut notches in the eraser end of it. make them steep V shaped notches and make them pretty deep. you don't want the rubber band falling out.
Step 4: Assembly
take the barrel and break off part of the clip thing. i've found that it works better this way.
put the shaft into the barrel. (should slide in and out right now.)
wrap the rubber band around the barrel a few times so you have it tucked against the side of the clip on the last wrap. it should be just long enough to reach the end of the shaft sticking out. you'll have to experiment on your own to make sure it works right. too tight and the rubber band will snap when you try to draw back too far. too loose and you won't get enough power.
put the loose end of the rubber band in the notches in the shaft.
and thats it!
Step 5: Ammo
This thing can shoot pretty much anything that you can fit into it. the best ammo however is the heavyest and smoothest things you can find. some of the best things that i have found to work are bb's and pellets for pellet guns. if you need impromptu ammo, bits of paper and eraser work well also. just be careful not to shoot someone in the eye with this thing, it will hurt.
also if you leave the end of the shaft on that sticks out the end, you can use it as a blunt object. if you put the barrel on someone and dryfire, it hurts A LOT. experimenting on myself produced some nasty welts.
have fun!
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Metalworking Contest
    • Puzzles Speed Challenge
    15 Discussions
    billiebob
    billiebob
    11 years ago on Introduction
    hey like every other time i shoot it a piece brakes off the pencil i figured out that if you cut a piece off a ear plug and put a hole in it then stick it on the bolt it works for a while but in the end it still brakes anyadvice to make it stop breaking?
    absolute zero
    absolute zero
    12 years ago on Introduction
    carry a dart with ya, take the pencil led holder out put the dart in and BLOW MAN BLOW!!!
    johndoe5595
    johndoe5595
    Nice name, is it based on Soundgarden's song or do you just have fun with black wholes?
    hilowns
    hilowns
    made mine wiht one of the bigger bands, so powerful, it breakes a lil bit of the pencil each time i shoot, but very nice instructable. :D, feels bout like being bit by a mosquito
    X_D_3_M_1
    X_D_3_M_1
    ur right elephant bic pencils fricken unreliable. yay for dr grip pencils they pwn
    nightninja87
    nightninja87
    plz dont shoot toothpicks trust me they go straight through the skin
    black hole fun
    black hole fun
    Reply 12 years ago on Introduction
    thanks for the tip. i take it you know this from experience... sounds painful.
    mondaymonkey
    mondaymonkey
    13 years ago on Introduction
    Hey, I did this kinda stuff in six grade. Exept we used geometry compass lead instead of bb's. You know those real thick things of graphite they use in special compasses? Works great until you hit someone.
    black hole fun
    black hole fun
    Reply 13 years ago on Introduction
    ok spit ball gun. we called it a pea shooter at my school.
    snipeyouout
    snipeyouout
    this isn't a pea shooter a pea shooter is the top of soda bottle with a balloon on the end
    yellow elephant
    sweet man. this is awesome. i made the first one and was good. gonna make this one now. best thing for those terrible pencils.
    thingygoboom
    thingygoboom
    been done but still i like the idea. Right now im doing some expirements with a rifled bore... crazy yeah
