Medieval Shield
Introduction: Medieval Shield
Hello there, today we are making a medieval shield here is what you need to create it.
Supplies:
1. 4x4 steel sheet 0.124 inch thick sheet metal
Cost- $13.60
Steel sheet
2. Black permanent marker
Cost-1.00 at local dollar tree(7 cents tax included)
3. DEWALT DCG414T2 60V MAX 2 Battery FLEXVOLT Grinder with Kickback Brake Kit
Cost-$289.99
Grinder kit
4. jigsaw
Cost-$279
Jigsaw
5. Rubber hammer
Cost-$5.47
Rubber Mallet
6 .Anvil or strong place to hammer
Cost-$16.20
Anvil
7. Screw and bolt kit
Cost- $8.21
Screw and bolt kit
Teacher Notes
Step 1: The Shape of the Shield Part 1
Get your 4x4ft+ metal sheet and lay it on a flat surface/ work space and draw a 26 by 29 inch rectangle on it.
Step 2: Cut Out the 29x26inch Rectangle
Use a jigsaw to cut out the rectangle. Make sure you use proper PPE.
I recommend cutting it out piece by piece because trying to cut big chunks out causes the sheet to wobble and will conclude in a bad cut.
Step 3: Shape of the Shield 2
Draw the shield shape and cut it out using the jigsaw. Then use the angle grinder to round out the edges. If you need to brush up on the basics I recommend watching this video
Link- https://youtu.be/puGg_UzpVo4
Step 4: Handle
Now it is time to create the handle
Step 5: Handle Part 1
You should have excess material from the cuts you've made. Get a big enough piece and cut out a 3inch by 10inch rectangle.
Step 6: Handle Part 2
Now get the 3x10inch piece of steel and put it into the bench vise about halfway down then tighten it as tight as possible.
Then use the pliers to bend the top of the sheet down then hammer it until its flat then do the same thing for the other side
Step 7:
Step 8: Handle Part 3
Use the anvil to hammer the 2 sides inwards one at a time so they fold inwards. keep hammering until the handle is semi flat.
Step 9: Handle Part 4
Next bend both sides of the handle outwards to create a place to screw down the handle.
Step 10: Now Use the Drill to Put Holes Where the Screws Go
Step 11: Now Put Holes in the Shield Where the Handle Will Go.
Step 12: Attatching the Shield and Handle
Drill in the screws from the front of the shield and into the handle then use a bolt to hold it in place.
Step 13: Use Bolts to Hold the Screws in Place
Step 14: Now Use the Grinder to Flatten the Screws. Make Sure to Not Hit the Bolt Otherwise It Will Come Off.
Step 15: Now Your Shield Is Done!!
I spray painted mine galaxy, Spray paint it if you would like.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    2 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    5 weeks ago
    Nice job putting this shield together :)
    ethan.jean.22
    ethan.jean.22
    Reply 5 weeks ago
    Thank you 🖤🧡
