Metal, Oil Burning Candle
6,317
22
22
Introduction: Metal, Oil Burning Candle
This is a small candle made of metal I used from around the house.
Note: The candle I'm making is only a small version. You could easily make a bigger one with a big metal tray (shoe polish lid) and a bigger nut.
Teacher Notes
Step 1: Materals
You will need:
- String (any will do)
- A nut (I cut one off of a chain link)
- A tray (I used a beer bottle cap)
- A hack saw or metal file
- Crazy glue
- A marker
- oil
Step 2: Marking the Nut
Take your marker and mark a cross on one end of the nut so it can be cut.
Step 3: Cutting
Using your hack saw of metal file, cut the cross markings about 1 to 3 mm in. You should be able to cut
2 marks at a time.
Step 4: Assembly
Use your Crazy glue and glue the nut with the groves facing down and seal it to the tray. DO NOT CLOG THE GROVES!These let oil get to to wick(string).
Step 5: The Wick
Cut your wick about 1/4" longer than the nut. Once the glue has dried, shove the wick down the nut so it will touch the bottom of the tray.
Step 6: Light
Pour vegetable oil into the tray. Give the wick some time to soak up the oil. Then light the wick.TA DA!
NOTE: If your string is coated with anything it won't work! Also the tray WILL GET HOT!
Tell me what you think of this instructable .
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • Trash to Treasure Contest
    • 3D Printed Contest
      3D Printed Contest
    22 Discussions
    hackysacker
    hackysacker
    10 years ago on Introduction
    this is awesome although I made one and I made it a little bigger and used a Fuze cap and a bullet shell
    strmrnnr
    strmrnnr
    10 years ago on Step 6
    Looks like an exceellent bon fire starter for the survival kit. The metal parts are recoverable. Just need a little 5ml of oil for a couple of lites and a match.
    plumber4
    plumber4
    Reply 10 years ago on Step 6
    Excellent idea! You could fit this in the Altoid tin emergency kit to use for light< heat or fire starting. Maybe use very small eyedrop bottle to store the oil.
    _zAp_
    _zAp_
    I really like what you did there, simple and defenitely a cool (or hot i guess) idea!
    Mitten
    Mitten
    12 years ago on Introduction
    it looks like if you knocked it over, you'd be in a mess of trouble.
    notjustsomeone
    notjustsomeone
    Reply 11 years ago on Introduction
    Not really, that's part of the beauty of such a simple design. By using oil -vegtable oil, new or what was leftover from making dinner- there is virtually no risk of igniting the spilt oil unless it somehow vaporizes. So unless the cap's getting hot enough to combust the oil or you think using petrol and a peice of shirt is a good idea, these types of "lamps" can be quite safe.
    DrCoolSanta
    DrCoolSanta
    Cool idea, and well I have seen bigger commercial versions of it. I live in India, where we have something called a Diya, an oil lamp made of clay. It is like a bowl and we fill it with mustard oil, and put the wick in it. The wick keeps absorbing the oil and burns. For got to mension that there is a slight depression in it where the wick rests. The flame never reaches the oil inside, and it lasts quite long. It is not much of an only Indian thing, but it is ancient, very ancient. Nice instructable, just don't play with the effects you can apply on the camera.
    littlechef37
    littlechef37
    Nice Idea im going to make one like this but im going to use the bottom of a pop can for the oil . Looks bright . what kind of oil did u use, lamp oil (parafin) ?
    A_squared
    A_squared
    Reply 12 years ago on Introduction
    ANY OIL! Thats what i like about it I jjust used veggie oil.
    space_thief
    space_thief
    what tijpe of veggie oil (sunflower or or other)
    littlechef37
    littlechef37
    I use canola but anything that says flammable will do
    space_thief
    space_thief
    I builded one today in like 3 min and it burns so good I used petrol with a piece of old t-shirt (white) as a string
    luver
    luver
    12 years ago on Step 6
    niceeeee! roll up a baking foil or tin or old tube. just nail some holes :) good i-d-Aa
    chuckr44
    chuckr44
    Hi, I made an oil lamp similar to this during the winter. I managed to find 100% cotton string but it did not work. The only thing that worked was thicker cotton wicks for oil lamps at the store. So, just be aware not "any string" will work every time. I even braided the string to make it thicker and it still did not stay lit more than 1 minute. A thick candle wick from the craft store might work, but I haven't tried it. Just an FYI.
    A_squared
    A_squared
    Yes I'm sorry about that. Not all string works. I found though 1/4 of a sheet of toilet paper works very well
    microman171
    microman171
    I really like this :D. I have been thingkning hwo to make this for a while now and never thought of that. Although I though this was tinfoil :( If you make tonnes of these then you are prepared for evac's power cuts... ect...
