Micro Spider Robot
In this project the development of a legged robot,which have needed features for search and rescue operations to access to survivors is aimed. Different walking algorithms are designed for this purpose and tested their performance.The legged robot inspired by spider is developed with the control mechanism and executes various walking behavior.
Teacher Notes
Step 1: Let's Gather the Components
1. Arduino nano x 1
2.power bank / 5v battery x1
3. Servos x 3 (sg90-pg micro servo)
4.3d printed chassis (stl files have been attached below)
Print with 50 % infill.
Step 2: Test-Code
just check your robot with code attached below, so that we can make leg adjustment, if needed.
Step 3: Adding Bluetooth to Your Robot
IF you successfully test the servos then, Now its time to add bluetooth.
Make the connections like below:
1.Arduino to bluetooth
Arduino 5v to Bluetooth VCC
Arduino gnd to bluetooth gnd
Arduino RX to Bluetooth TX
Arduino TX to Bluetooth RX
Servo connections should be as per the program.
Now download the code and test your robot.
use any blueterm application.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
