Middle Earth Toilets
Toilets are the best place to travel, here a map of the lord of the ring
Supplies:
Paper rope pencil marker painting
Teacher Notes
Step 1: Choose the Map and Prepare It to the Wall
First take all the measures of the walls of the toilet space, height, width etc. then put them on a piece of paper.
Then, use a computer with layout software to scale up the measurements you have taken. Then import the card you want to reproduce on your wall.
Finally, draw vertical and horizontal lines at the same distance to create a squaring of edges that will be used to reproduce the scale map on the wall
Step 2: Prepare the Walls for the Grid
Clean the wall to be painted, recap the holes if necessary, put a white paint after. Let dry. Put a color painting of your choice of old map (yellow/beige)
then wall by wall, postpone the grid not with a pen but with string and tape at the top and bottom And right and left to reform the drawing grid
Step 3: Draw the Map on the Wall
Use a pencil to draw square by square the drawings of the map on the wall
Step 4: The Map Drawing Is Done
The map is now drawn on the wall with a pencil you can remove all the string that formed the grid
Step 5: Painting the Map
You can now use a Poska paint pen to draw again the pencil and reveal the map of your choice !
Maps Challenge
Maps Challenge
1 Person Made This Project!
  • Made with Math Contest
  • Cardboard Speed Challenge
  • Multi-Discipline Contest
Cyroul
17 days ago
Il fallait y penser. Absolument génial ! Bravo !!
