Introduction: Minecraft Pe Elevator
Have you every built a really tall tower? And you need some way to get to the top quickly? Well here is the answer!
This is a working elevator, made with signs and water!
Step 1: You Will Need
The amount materials needed varies, it depends on how high the elevator is.
Buckets of water
Signs
Doors
Blocks ( the blocks you would like for the elevator)
Step 2: Building the Elevator Part One
Start by using the blocks and making a 4x1, put two blocks at the side of each end. Build this another layer high, place two doors in the middle. as in pictures
Step 3: Building the Elevator Part Two
On the door place two of the chosen blocks. Put the water on the space between the doors and the wall, place two signs on top of the water. As in pictures
Step 4: Building the Elevator Part 3
Repeat part one and part two until the elevator is as high as you need it to be.
