Introduction: Minecraft Tutorial Quickie #2 - Tiny Ocean Liner!
Hello, my name is AssassinzSinpZ and today I am finally back after my long absence with a new Minecraft Quickie - a tiny RMS Empress of Russia. Hope you enjoy, and leave a comment and a like. Thanks for reading!
Step 1: Under Hull/Belly
This step is quite simple, you just lay a 12 block long red stained clay line 1 block underwater. You then add 9 blocks to the sides accordingly.
Step 2: Over Water Hull
This step is also very easy, you just add black stained clay on top of the red stained clay accoordingly.
Step 3: Superstructure
This step requires a lot of quartz and is very intricate, but it is very easy if you follow the pictures.
Step 4: Bridge, Funnels, and Deck Details
This step is probably the easiest one, you just add a quartz slab in the middle on top of the 3 quartz stairs in front. You also add 3 cobblestone walls divided by one block, and another quartz slab behind the third cobblestone wall.
Step 5: Aannnd... You're Done!
You have completed this small and easy tutorial, good job! Please leave a like and a comment, and follow me for more!
Peace out, told you it would be quick.
