Mini Drill With Router Base
1,074
11
About: Diy and gadgets
Dremel with 550rs motor and small stand for some routing jobs
Check the video above for see it working
Material list:
550 motor: http://bit.ly/2S7y8NI
or https://goo.gl/x7espH
Drill chuck: https://goo.gl/hN2uAM
or https://goo.gl/EFykPw
Speed controler: https://goo.gl/nWJBku
or https://goo.gl/Najw9o
Power jack : https://goo.gl/J7VrHg
Teacher Notes
Step 1: Motor and Case
Its a very simple process, find a plastic tube with similar diameter of the motor, drill some holes for air ventilation, fit the motor inside the tube, do small suports for the screws using the tube and secure the motor.
Step 2: Final Steps
Screw the drill chuck into the motor, add the speed controler to the top part using a plastic piece with the necessary holes to fit the speed controler knob, on/off switch and power jack
Step 3: Lets Test It !
this 550 motor as a good amount of torque, is really strong, you can also use the 555 motor because it has the same size, this chuck allow to use nearly all the dremmel acessorys and small drill bits up to 4mm, i also did a small router jig to use with my mini dremmel machine, very usefull i have used in many of my builds.
Tank you for watching !
Build a Tool Contest
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • CNC Contest
      CNC Contest
