Mini Headphone Amp
9,455
119
25
Introduction: Mini Headphone Amp
About: I've always liked pulling things apart - it's the putting back together again that I have some issues with!
Make a small headphone amp from off the shelf modules.
I made this headphone amp after getting frustrated with terrible sound quality coming out of my headphones whist on a recent plane trip to China. The sound was tinny and sounded like I was sharing the same audio driver with about 300 other people (probably was!)
Building a small, portable headphone amp helps drive the speakers in your headphone and dramatically improves the quality, clarity and detail of the sound.
You can use this headphone amp as an everyday amplifier for your headphones if you want as well. I’ve also tested it recently on a plane trip and it worked a treat.
I’ve made a couple of other versions of these amps which can be found here and here
The amp uses a few off-the-shelf modules that you can get from eBay. I also stuck it all into a 2 X AA battery holder which ended up being just the right sized case.
So without further ado – let’s get cracking
Step 1: Parts & Tools
Parts
1. 2 X 3.5mm headphone jack sockets - eBay
2. Headphone amp module – eBay You can also put into eBay - Headphone Power Amplifier Board to find other types
3. Lipo battery – eBay
4. Lipo battery charger – eBay
5. 2 X AA battery holder – eBay. This is the case that you will be modifying. You could also use a 9v battery one which you can buy on eBay
6. Thin wires
If you are using this on a plane then you’ll also need the following:
7. Plane headphone adapter – eBay
8. Male to male headphone jack adapter – eBay
To connect the amp to your phone you’ll need the following:
9. Male to Male Headphone cord - eBay
Tools:
1. Soldering Iron
2. Pliers
3. Super glue
4. Drill
Step 2: Modding the Case and Adding Headphone Jacks
Steps:
1. In order to fit all the parts inside the AA battery holder, you will need to make a few modifications. First, remove the plastic divider in the middle of the battery holder
2. Next, remove the battery terminals
3. Remove any gussets or pieces of plastic that aren’t needed.
4. Next, drill a couple of holes into the end of the case. These will be for the headphone jack sockets. Don’t drill the holes too low as you will need to fit the amp module under tem later on
5. Connect the 2 sockets to the case with the connector rings
Step 3: Adding the Charging Module
The battery is charged via a charging module, which has a micro USB connector. You need to make a small slit into the side of the case so it is accessible.
I've also included a circuit diagram so you can see how everything is sired-up. Please note that it's only for reference.
Steps:
1. Measure and mark where the USB connector will come out the side of the case and drill some small holes
2. Use a file to smooth and shape the slit for the USB connector
3. Once it’s the right size, add some super glue to the bottom of the charging module and glue into place
4. Be careful that you don’t get any glue on the USB connector
Step 4: Wiring the Jack Sockets to the Amp Module
There isn’t much room inside the case so you will need to use the thinnest wires you can get your hands on. I used some thin ribbon cable, which worked well.
Steps:
1. Solder 3 small pieces of wire to each of the solder points on the jack sockets.
2. Trim these to size and tin each end of the wires
3. Add some solder to each of the solder points on the amp module. You will notice that there are 3 solder points for in and out and a couple for power.
4. You now need to solder ground on the jack socket to ground on the module. Ground on the socket is the larger leg in the middle.
5. The other 2 are left and right audio. Solder the wires from the socket to each of the left and right solder points.
6. Make sure that you solder the 2 sockets up the same way. So the left solder point on each of the sockets should be soldered to the left solder point on the amp and so on.
7. Solder on a couple of wires to the power solder points and carefully push the amp module under the sockets so it is out of the way.
Step 5: Wiring the Battery to the Charging and Amp Modules
The next thing to do is to connect the battery and amp module to the charging module.
Steps:
1. Top connect the amp module to power, the best thing to do is to connect it directly to the solder pads on the charging module.
2. The great thing about using the AA battery case is it has a built in on/off switch! Solder the positive wire from the amp to one of the solder points on the switch.
3. There will be a wire already soldered to the other solder point of the switch. Attach this to the positive solder point on the charging module
4. Next, solder the negative wire from the amp to the other solder point on the charging module
5. Lastly, solder the positive and negative wires of the battery to the charging module.
Step 6: Adding an LED "on" Indicator
I decided at the last minute to add an LED to indicate if the amp is no. There's even a hole already in the case there the wires used come out from!
Steps:
1. Solder on the 3.3K resistor to the positive leg on the LED. You'll also need to trim the legs of the LED and resistor.
2. Solder a couple wires on to the legs of the LED and resistor.
3. Next, place the LED into place and use some super glue to secure it.
4. Solder the positive wire to the switch and the negative to the negative solder point to the charging module
Step 7: Using Your Headphone Amp
Now that you have everything wired-up, it’s time to give it a test run.
Steps:
1. Plug your headphone jack into the out socket on the amp. If you have forgotten which one is out and which is in, then don’t worry – just swap the jacks over if you don’t hear anything
2. Next, use the 3.5mm cable and plug one end into the amp and the other into your phone
3. Turn the amp on and start to play some music from your phone. Make sure though that your phone isn’t too loud or you might damage your ears!
4. If everything is soldered correctly you will hear some sweet music. If you hear nothing, then try to swap the jacks in the amp. If there is still nothing then you will need to check your connections to see if anything is wrong.
5. You can also grab yourself a Bluetooth connector like the one that can be found here and plug it into the amp. This way you’ll have less cords to worry about and when using it on a plane, you won’t have to worry about any cords at all!
6. Lastly, get on a plane and give it the ultimate test
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    25 Discussions
    NoelA11
    NoelA11
    Question 1 year ago
    the Headphone amp module link goes to a different board than the one you use in this project, why is this? and will it work for this project? i have one and not sure how exactly to use it. i have the rest of the build waiting for installing the board but im at somewhat of a standstill as i don't want to screw up this project.
    lonesoulsurfer
    lonesoulsurfer
    Answer 1 year ago
    I think the reason was due to the fact that people in the US couldn't get the one I had linked. I have now linked the one I used and also added a little more search info in-case it's not available in the US. Send me an image of the board and I'll show you how to wire it up
    NoelA11
    NoelA11
    Reply 1 year ago
    by the way, im in New Zealand, not the US
    NoelA11
    NoelA11
    Reply 1 year ago
    this is the board i have
    KISELIN
    KISELIN
    1 year ago
    Nice job. It was clever to use the battey holder. I have of those exact same ones laying around just waiting for to be used to something. Now they'r gonna be a home for something.
    Just a note: the resistor for the LED you say "3.3K" really?
    I would rather go for 330R @3,7V = a bit > 10mA
    kschmidt2
    kschmidt2
    Reply 1 year ago
    3.3K can't hurt though, less current for the LED means more for the amplifier, probably saved some runtime like that.
    KISELIN
    KISELIN
    Reply 1 year ago
    Hmm... to me it's like R=U/I => U seems to be ~ 3V and "I" for a LED to illuminate so.. and so.. would be about 10mA, to illuminate properly it would take appr. > 15mA. So, R would be Vc- LED forward (1,8V), with V= 3V gives you: R= 3/0,015; R= ?
    Com'on, to put there a 3,3Kohm res.??
    lonesoulsurfer
    lonesoulsurfer
    Reply 1 year ago
    Cheers. Yeah I only used a 3.3K and it has seemed to do the job. Although I only guessed at the value so I'm sure a 330R would be a better choice.
    robertmro
    robertmro
    1 year ago
    Can it be used with a condenser microphone?
    kschmidt2
    kschmidt2
    Reply 1 year ago
    No, Condenser microphones require a powered line, usually Phantom power, second issue is this amplifier is expecting headphone level out put, so it's looking for a signal of about 200mW, where as a condenser or even electret microphone outputs well below that.
    So it won't work, what you're after is a condenser amplifier, which, you could probably buy, or a pre-amplifier that would allow it to work with this.
    lonesoulsurfer
    lonesoulsurfer
    Reply 1 year ago
    No I don’t this amp would work with a condenser mic. It’s made for low impedance speakers such as the ones you find in headphones.
    smokebox
    smokebox
    1 year ago
    Doesn't post to United States.
    lonesoulsurfer
    lonesoulsurfer
    Reply 1 year ago
    One of the parts? Which one? Just grab the description in the parts list or from eBay and look it up in the US version. Let me know if you still can’t find it and I’ll add a link.
    smokebox
    smokebox
    Reply 1 year ago
    When you click the link for the module, the result is a page on eBay that displays the message that it doesn't post to the United States. Tariff problems, maybe?. Thanks! I will "Google" it separately.
    lonesoulsurfer
    lonesoulsurfer
    Reply 1 year ago
    I’m sure you should be able to get an equivalent from another seller on eBay. Here’s the full description of you need it - Headphone 150mW Amplifier Board Differential Balanced 4812 HIFI Amp SGM Module
    smokebox
    smokebox
    Reply 1 year ago
    Thank you, again. I was able to find the parts elsewhere on eBay and also AliExpress. It looks like a sweet project that I intend to build sometime soon. I've been collecting headphone amp schematics for the past few years and this looks like the best and simplest solution to what I was looking for.
    lonesoulsurfer
    lonesoulsurfer
    Reply 1 year ago
    My pleasue. I've built a few myself (also been collecting schematics as I came acorss them). This def is one of the simplest ways to put one together.
    Good luck with the build
    Jracey
    Jracey
    1 year ago
    Well done and simple. Thank you.
    askjerry
    askjerry
    1 year ago
    This is brilliant! I must travel 20-40 times a year... and my Android phone just won't cut it on a plane ride when I'm in a seat near the engines... I've always wished i could just get that extra 10% audio... this should do it perfectly. You are a genus... I have to build two immediately!
    THANK YOU!
