Mini Lathe Machine
About: Qatar Science and Technology Secondary School is the first stem based learning school in Qatar. in our fablab students use the engineering design process to build solutions to local and global problems. in t...
lathe machine is one of the earliest machines man used to create things. it's versatility made it popular in many sectors including the automotive, aerospace, military, and many other industries.
the purpose of this project is to make an inexpensive lathe machine. that can be used both in the educational field and as a prof of concept for the proposed design.
the students designed, fabricated and assembled the project in their digital fabrication class on a span of 3 weeks.
Teacher Notes
Step 1: Design
the students used solid works to design the parts. most of the parts we started from the engineering drawing and they make the 3d model.
there are 8 components that needs to be digitized for fabrication.
-The Chuck
-Slider
-Tail-stock
-Coupler
-Wheel
-Motor mount
-Motor holder 1
-Motor holder 2
Step 2: Fabrication
we used digital fabrication tools like 3d printer and CNC router for most of the parts. for the base we used the hand and power tools.
the chuck, motor holder and motor mount were 3d printed. while the wheel, slider and tail-stock was cut in cnc.
all the 3d printed parts design were inserted to Cura Ultimaker and then they were printed using Ultimaker 3 Extended.
for the cnc parts design we used easel inventables in a dxf format and then fabricated it using X-Carve.
Step 3: Assembly
Step 4: Final Prototype
Students Feedback:
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • Reuse Contest
      Reuse Contest
    seamster
    4 days ago
    Nice work, thank you for sharing your project : )
