Mini Lego Robot Wars - Rapid
About: I love building with k'nex and lego. I like building knex odd objects such as coasters and combine harvesters but I'm not very good at making my own knex ball machine yet. I would appreciate some advice abou...
Hi, this is just a mini version of lego Rapid with working flipper.
Teacher Notes
Step 1: Step 1. You Will Need:
1x 4x4 tile
2x 2x4 tiles
2x 2x2 circular tiles
2x 2x2 slope
2x 2x2 circular plates
2x 2x1 slopes OR 1 1x4 curved thing(like 2 2x1's put together, back to back).
4x 1x4 plate
6x 2x2 square plate
3x 1x2 plate
1x 1x2 plate with bar hinge
1x 1x2 plate with clip
2x 2x4 plate
2x 2x1x2 plate 90 degrees 2 studs on the bottom 4 up the side
2x 1x2x1 plate 90 degrees 2 studs on the bottom 2 down the side
Step 2: Step 2: Middle Chassis
You will need: 5 2x2 square plates
2 2x1 plates
1 2x4 plate
2 1x4 plates
The Step
Underneath the three 2x2 plates is the 2x4 plate.
Step 3: Step 3: the Wheels and Side Armour
You will need;
The thing you've already built,
2 2x1x1 90 degrees 2 along the bottom and 2 down the side,
2 2x2 circular plates,
2 2x2 circular tiles,
2 2x4 tiles,
and 2 2x1x2 90 degrees 2 along the bottom (width) and 4 up the side(height).
Step 4: Step 4: Top Bit
You will need;
2 1x4 plates
1 1x2 plate
1 4x4 tile ( or 4 2x2 tiles)
1 2x2 plate
1 1x2 plate with clip.
Step 5: Step 5: the Weapon
You will need;
everything that's left.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
