Mini Lighthouse Lamp 2
124
About: I am IT professional, living in Bangalore, India. As new gadgets come out everyday, we indulge in spending significant time and money on these gadgets. And our kids are learning from us, they know how to use...
Hi All,
Few months back I had made my first version for Mini Lighthouse Lamp, I faced few challenges, and wanted to improved my design and making process by
  • Using PVA glue, It takes more time, but the bond is better
  • Using small Glass jar, so no more cutting
  • Enhance pebbles texture painting
  • Recycle items that are easily avaliable at home
In this instructables, I have improved all of the above... Hope you like it
Supplies:
Step 1: What Do We Need ?
Material
  • Pringle box (Empty it, if full)
  • Small Hexagonal Glass Jar
  • 4 mm MDF Sheet
  • Bamboo Skewers
  • LED Strip
  • LED Driver
  • Wires
  • PVA Glue / Fevicol
  • Pebbles
  • Acrylic Paint and brush
  • Popsicle stick
Tools
  • Dremel
  • JigSaw
  • Sandpaper
Step 2: Prepare
  • Before we start, we need to sort pebbles
  • I have sorted into 3 stacks :
    • Flat and thin upto 2 mm thickness
    • Long, Flat and Thin upto 3 or 4 MM thickness
    • Rest
  • We will use flat and thin pebbles as bricks
  • And Long pebbles as frames for doors and windows
  • Cover the pringle box with a brown paper or any other color of your choice
  • Let it dry for 30 minutes
Step 3: Tower
  • To build the tower, start with doors and windows frame
  • Then fill the space in between using flat and thin pebbles
  • Once the whole box is done, leave it to dry for 5 to 6 hours
  • Add doors using popsicle stick
Step 4: Base Roof
  • Measure the outer diameter of the glass rar (neck) and pringle box with pebbles
  • We want to cut a ring from MDF, with inner diameter same as glass jar's neck and outer diameter little more than the pringle box
  • Add cardboard at the inner diameter and cover it with the another ring of mdf sheet
  • Add 6 skewers as shown
Step 5: Roof
  • I have used a hexagonal glass jar, so added 10mm to the length of one side
  • Then made ad hexagonal prism as shown
  • I secured the edges with paper tape and glued the roof from inside
  • Let it dry for 1 hr and then remove paper tape
Step 6: Electric Work
  • Since I am using a small glass Jar that fits on a pringle box, i cannot fit a regular size bulb,
  • I must make my own mini LED bulb.
  • I am using 2 LED strip / elements that I have stuck on a 15 mm PVC pipe
  • Each element has 3 LEDs and a register
  • These LED elements are connected to a led driver circuit (12V)
  • Test the circuit before final assembly
Step 7: Paint Job
  • Tower
    • Based coat with black acrylic paint, and let it dry for 1 hour
    • Mix 3 parts of white ad 1 part black on a pallet, do not add water
    • using a sponge cover all pebbles, Note that we want the gaps to remain black and pebbles as grey
    • Once done let it dry for 1 hr
    • After drying make a black watery wash and cover the whole tower
    • Leave to to dry
  • Base / Roof
    • Paint everything brown or a shade of light brown, to simulate wood colo
Step 8: Admire
  • Once done, Set the lamp in the corner and light it up
  • Admire great work done
Please share comments and suggestions
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    jessyratfink
    13 days ago
    The paint job is really well done. It turned out great :D
