Minitel Real Time Clock
1,065
8
5
Introduction: Minitel Real Time Clock
About: Artist painter electronics programmer
Created in 1978 by France Telecom, Minitel was an information retrieval and texting service. Considered to be the most successful network prior to the world wide web. 30 years on in 2008 the network finally closed. (There is lots of info about this on Wiki.) overnight these terminals became obsolete.
Consisting of a CRT screen keyboard, modem and some shift registers, these "dumb" terminals are not capable of processing data. So what can you do with it ? Turn it into a clock !
Teacher Notes
Step 1: List of Componants
Atmega 328p microprocessor with Arduino bootloader
16 mhz crystal
22 pf capacitor x 2
10 kOhm resistor
100 uf electrolytic cap
DS3231 RTC module
header pins for easy connection
(10kOhm & 100kOhm resistors : optional)
some wire and solder
Arduino Uno board for uploading sketch
And, of course, a Minitel 1 terminal
Step 2: Schematic
The schematic is very simple. It's your basic Atmega328p setup with the RTC connected to analog pins 4 & 5. Minitel rx and tx connected to digital pins 7 & 8. That's basically it. In one of my examples I have added a couple of resistors to create a voltage divider which is attached to analog pin 3. The minitel can now be a DC voltmeter up to 50 volts. You can also add other peripherals, such as an LDR, thermometer, microphone etc. The schematic that I have drawn does not have the voltage divider resistors shown. You may want to add other things, different values or leave it out altogether.
Step 3: Wiring Up
ATTENTION : Before removing the Minitels casing, make sure you have disconnected it from the mains power supply and allow 5 minutes for the high voltage capacitors to have drained.
There is plenty of room inside the Minitel for your circuit, but make sure it doesn't touch any other parts. I have screwed mine to a removable back panel.
Connect the RX and TX of your circuit to the TX and RX of the Minitel. see photo and schematic. If you connect these the wrong way, it's no biggie, you can simply swap the pin numbers in your code. (more on that later)
Locate the Minitels 7805 voltage regulator and connect your circuit to it. (Make sure you get your polarities correct. Always ! always ! always !! double check before switching it on.)
On the back of the Minitel there is the old France Telecom telephone plug and socket. Disconnect and removed the plug and lead. Next, connect the socket terminals to your circuit. You will be able to modify and upload new sketches to you circuit by simply connecting your Arduino Uno board to the socket without having to open and remove your microcontroller. Also, you can connect your analog pin to one of the terminals to add other peripherals, as mentioned in the previous step.
Step 4: Up and Running
Here are some images.
Step 5: The Code
The code uses three libraries. SoftwareSerial, Minitel and DS3231. All can be downloaded from GitHub. The call function Minitel m(7,8) sets up the Minitels RX & TX on digital pins 7 & 8. (These can be changed to other available pins in you want)
Then there is all the integers and character arrays for the large digits and space invaders. setup() starts the real time clock. (you can set time and date here if you want. but remember to edit or grey out the set time function so the time does not reset every time you turn the Minitel on)
As the Minitel 1 is slow and has very limited graphics capabilities, (40 years old) it's important to keep your functions as short as possible. The main Loop deals with reading the key presses and selecting the mode. In the menu and setting modes, there is no reading of the RTC and refreshing of the graphics so inputs from the keyboard are read quickly. However; in clock mode key pressing can take several attempts to works. Be patient.
This example code is for an alarm clock version and not the volt meter. If you want the code for the volt meter I will send on request.
I'm not going to talk all through the code. You have probably skipped this part already.
My code is very rough and messy. I really need to clean it up. but it works. When I have time I with streamline it and erase unused integers and stuff.
Thank you for looking. I hope your Minitel clock project goes well.
Luke. IG luke1969morgan
Clocks Contest
Clocks Contest
Be the First to Share
    • Tiny Speed Challenge
    • Clocks Contest
      Clocks Contest
    • PCB Design Challenge
    5 Discussions
    meatfest
    meatfest
    3 months ago
    Hi I cant get the case off.. there are 2 clips underneath near the front. Is there anything else to release the cover? Any schematics/manuals available... thanks in advance, James
    mooky69
    mooky69
    Reply 3 months ago
    Hi James, there are several different case styles out there. The brown and beige one that I have pictured in the instructable is the easiest. Two clips near the handle can be levered with a screwdriver, then the casing can slide back. Can you send me a pic of your Minitel. luke1969.morgan@gmail I will have a look at the other models that I have. If you need the code, I will send it to you .
    meatfest
    meatfest
    Reply 3 months ago
    Hi thanks for reply. Clips very brittle ; I had to snap a couple but the case is off now cheers
    claudius13
    claudius13
    Question 1 year ago on Step 5
    Nice project :-)
    just a question, I cannot find arduino code.
    is possible to get ?
    Best regards
