Mod Radio-cassette Player for Ipod & MP3
43,648
46
41
Introduction: Mod Radio-cassette Player for Ipod & MP3
Modifying an old portable radio-cassette , so that it will play (loud) with any MP3 unit or ipod.
Basic soldering skills recommended, minimal list of parts.
By using a ziplock bag, you make your ipod or MP3 player splashproof , so you can listen to it while in the shower.
Step 1: Headphone Cables
Take a pair of old headphones, cut away the headphones and strip the cables.
Use a cutter, but be very careful not to slice the cable.
Most of us have cheap earphones that were given to us by an airline.
I use these as the cable is relatively thick and easy to strip.
You only need the plug and 50 cm of wire.
Alternatively you can buy a plug and wire.
Step 2: Open the Radio-cassette
With a Phillips screw driver open carefully the radio-cassette.
Keep all the screw, and (if possible) remember where they came from.
Step 3: Recording Head
Locate the recording head.
There are 3 wires connected to it.
One white, one red and a ground.
Solder them off, or cut them off.
Step 4: Disconnect the Motor
Cut off the wires of the motor of the cassette-player, you won't need it anymore.
The player will be quiter without the motor hiss.
Insulate the wires you cut off.
Step 5: Connect the Wires & Test
Solder the wires coming to the recording head to the wires of your plug.
Of course white to white. Red to red. Ground to ground.
Test the whole setup to see if it works, then insulate them well.
Step 6: Make a Holder for the Ipod or MP3
Not necessary, but it is nice to make a holder.
Use a plastic box to hold your MP3 player or ipod in place, so it won't slip.
You can even splashproof it with a ziplock.
Step 7: Listen to the Music
Turn on your cassette-player on "cassette"
Use a low volume setting on your MP3 or ipod, otherwise you'll have distorted sound.
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    41 Discussions
    mastermakoko
    mastermakoko
    8 years ago on Introduction
    Where does the stereo wire plugs out to the "surface"?
    How do you keep your ipod in place like that?
    wout smeets
    wout smeets
    9 years ago on Step 3
    i find it out desolder the 2 ends ensolder that to te male audio plug u gottah cose left or right
    sorry for my bad inglish i come frome belgium
    chefmichel
    chefmichel
    Reply 9 years ago on Step 3
    Great to hear that you are Belgian !
    Ik ben een Belg , moi aussi, je suis Belge.
    Uw vraag is niet duidelijk.
    Votre question n'est pas claire.
    ivanjacob
    ivanjacob
    gaat de versterker niet kapot?? want de leskop geeft een onversterkt singaal en je mp3 is versterkt...
    chefmichel
    chefmichel
    Yes the signal from the MP3 is amplified, but the casette amplifier will not blow.
    Just keep the voume of the MP3 player low, otherwise you'll have distortion.
    dandrade4
    dandrade4
    8 years ago on Step 5
    a lot of newer headphones have cheap thinner wire which is hard to use so it'd be better to get new wire for this. if you can manage or have the right materials to remove the enamel from the cheapo thin wire - they aren't always white red and black. maybe red and blue/green and one copper on each side. so two coppers to the one un-shielded wire and red to red blue/green to white. I would say. that's what i've done when splicing audio devices together.
    wout smeets
    wout smeets
    does your boom box has 1 spaeker
    chefmichel
    chefmichel
    Look at the first picture.
    My boombox has 2 speakers, but I guess it might work with only 1 speaker.
    bittu 1
    bittu 1
    10 years ago on Step 7
    i had the jack with 3 wire but it broke a now ithas 4 wires 1red 1whait and other 2 without cover will this wire work
    chefmichel
    chefmichel
    Reply 10 years ago on Step 7
    Dear Bittu, it might work.
    Experiment, try the red, the white and one without cover.
    Bare wires of the red, white and without cover should not touch  eachother.
    Ask somebody who as some experience in electronic projects for help.
    Good luck to you, have fun.
    Chefmichel
    stone3408
    stone3408
    13 years ago
    Nice Job. Simple effective and good photos. I'll be off to the local second hand store for an old radio. I'm hoping to remove all of the casette mechanical parts and have space to put the mp3 player inside the unit through the old cassette door. Very cool.
    chefmichel
    chefmichel
    Reply 13 years ago
    Hi Stone, I thought of that too, it is very feaseable, i removed the mechanism, but put it back in, for a few reasons. Removing the mechanism will leave a gap where the buttons were. Most important, I am effraid of the magnets, as Ipods are very sensitive to magnets.You can erase the HD by coming too close. An interesting question; how close can you come to a magnet but be safe ????
    raimen
    raimen
    In response to the Magnet idea, I have an old (2nd Gen?) Ipod Nano, and was testing different things on it, one of which happened to be a magnet I bought online from Unitednuclear.com, and it had no effect on the ipod. The magnet is registered at a 150pound pull force (easy to crush fingers, even picks up nails from more than a foot away) and had no effect whatsoever. :D
    ~L
    stone3408
    stone3408
    Reply 13 years ago
    Good point about the magnets. I'm using a flash based Mp3 player but, its a problem for ipods.
    LasVegas
    LasVegas
    Reply 13 years ago
    It would take a magnet stronger than one you'd normally run into to damage the data on a hard disk. You might be able to do it if you pulled one from another drive or better yet, built a large electro-magnet. The magnets in a tape player couldn't effect an iPod or any other MP3 player. BTW: Ipod Nanos, Shuffles and many smaller MP3 players use RAM and wouldn't be effected by a normal magnet. Perhaps an electro-magnet able to produce a strong enough magnetic pulse, but that could take out anything electrical.
    Fenwick
    Fenwick
    13 years ago on Introduction
    You are partially mistaken with the stereo wiring. The bare wire is actually positive, and the red and white are negative wires.
    raimen
    raimen
    Sorry bud, I may be incorrect, but I do believe that red is "positive", white is "negative", and the bare, copper wire is almost always ground.
    ~L
