Modern Dollhouse Made From Plywood.
Introduction: Modern Dollhouse Made From Plywood.
About: I'm a woodworker / content maker on Youtube.
Welcome back. This time i'm building a modern style dollhouse for my daughter's birthday. she turned 5 years old(young) last week. enjoy the build and if you have any questions about this project. please ask!
Teacher Notes
Step 1: The Materials You Need.
This modern dollhouse is made from 9mm, 12mm and 18mm plywood. (3/4") The two sidewalls are 80x35cm. the first and second floor are 60x35cm. the backwall is made from 12mm plywood. The paint is a water besed white coloured paint. the legs are from an old table.
Step 2: The Build.
i started with the backwall. i cut it on the right size. after that i started with bot side walls, the roof. next step were both floors.
Step 3: Cutting the Windows and Putting Wood Filler.
When this all was finished i started with the windows. meassured them and cut them out with my jigsaw. After this i could fill all the screw holes and small gaps with wood filler. sanded it down with my orbit sander and 120 grit sand paper. Just to get a very smooty result.
Step 4: Painting the House and Putting the Legs On.
Now it is time for painting. i used a water based wite paint wich is safe for kids. First step you have to do is cleaning everything. for a good and smooth paint finish. i gave it two coats of paint. The legs are from an old coffee table. those were perfect for this house. just had to cut off 15cm for a perfect hight.
Step 5: The Result.
this is the result. Now hoping my daughter will like this! fingers crossed!
if you have any question or like to share your opinion. please add a comment below!
see you all nect time!
Be the First to Share
    • Toys and Games Challenge
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    2 Discussions
