Mooomba - the Cow Roomba
2,038
15
6
About: Hi, we’re Dane & Nicole, two makers that create stuff, which we happily share with you!
Always wanted a cow, but don't have the space? Build yourself this Roomba-sized cow!
Below a quick overview of the content.
  • Introduction and showcase video
  • Movement
  • Control
  • Sound
  • Style
  • Adventure
Supplies:
Raspberry Pi 3 Model B
Seeed Grove - 2-Channel SPDT Relay
Battery Holder, AA x 8
Powerbank 5v 2.1A
Adafruit Mini External USB Stereo Speaker
Wheels (2)
DC Motor - 37mm - 12V - 50RPM (2)
Swivel Wheel
Cow
Fake grass
Wooden Platform
Hot glue gun (generic)
3D Printer (generic)
Paint
Multitool, Screwdriver
Scissors, Free Fall
Teacher Notes
Step 1: Introduction and Showcase Video
My girlfriend really wants a cow. Sadly, that's a bit tricky because we live in an apartment.
I did however find a small inflatable version in the local thrift store.
This means we can make her a robot cow for adventuring, The Mooomba!
Step 2: Movement
A cow can move around, so our Mooomba needs some wheels and power to match.
Two DC motors in the front and a small swivel wheel in de back will do perfectly!
To attach the motor we drill two holes on each side, and using the motor bracket, screw them both in place.
Here's a dirty bit, the wheels I'm using don't really fit on the motor shaft.
To fix this we're going to us some hot glue, I know....
We can attach the swivel wheel in exactly the same way.
With our motors, wheels and swivel in place we can test if it has enough oempf to move around our pint-sized cow.All we need to do is attach the motor wires to a 12v power source and see what happens.
Our miniature herbivore can move, woopwoop!
It's still manually controlled though, let's change that by mo(o)ving on to the next part.
Step 3: Control
To make our lives easier and give the Mooomba a sense of self, we're going to add some electronics.
The Raspberry Pi is powered by a 5v powerbank (black block on the left).This Pi controls a two channel relay (black/blue thing on the right). The relay on its turn will open/close the connections between the 12v battery pack and the two motors. This means;
Both relays open => no power => no movement
Both relays closed => both motors powered => forward
One relay closed => one motor powered => left or right
We want to make a high quality cow, so we 3D print some braces to keep everything in place. The files for these braces are attached to this article.
All that is left to do is write some code. You can find the full code in the section "Code", but here's a overview of how it works.
Generate a number between 0 and 3 and do the following;
0 => Forward
1 => Turn right
2 => Turn left
3 => Play audio (see next section)
This is repeated until eternity, or the batteries run out.
Step 4: Sound
Every cow can make sound, so ours will too!
The first thing we need is a volunteer to do their best cow impression on camera.
We take this audio and save it as mp3, adding a USB speaker makes sure everyone can hear Mooombas majestic calls.
Step 5: Style
Last but not least, some style.
To really bring out the best we add some fake grass to our moving platform, give Mooomba a good wash and add the all important cowbell. Doesn't she look fab?
Step 6: Adventure
Now you're all ready to go adventuring with your mini cow!
Just don't forget to stop and smell the flowers. :-)
Make it Move
This is an entry in the
Make it Move
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    6 Discussions
    JonathanL236
    17 hours ago
    This is adorable! My friend has this same cow, and she calls him Mr. Moo Cow.
    Orngrimm
    Question 6 days ago
    Where did you get the cow from???? It is super CUTE! :)
    1 answer
    Pa1963
    4 days ago
    I think your cow might say "don't forget to taste the flowers".
    MsHartline
    4 days ago
    Love it.Very Clever!
    instructodad_
    7 days ago
    Hahaha- Love it! Fun project:)
