Mosaic Planter
Introduction: Mosaic Planter
About: What about me???? I don´t know what the h ask me anything but don´t expect a serious answer but for real If you want to connect do it
„mosaic“ Planter pot for flowers or
other stuff
Are you a crazy Horder that can´t throw any wast pieces of wood away, like me ? This i the tutorial for you! I had very smal pieces of very beautiful wood like lilac and boxwood, so I startet making Rings. But what to do with the pieces that are slightly to smal for rings? Or even the ones you cut of the pieces of the pieces you make rings out of...
Step 1: Become a Horder If You Are Not Already
collect all the good wood pieces in all
sizes
Step 2: Glue Two Pieces Together
Maybe take all your clamps and put two flats on two sides and then but some glue on the flats and then clamp them. Try diffrent angles and so on even if it makes it harder to clamp
Step 3: Glue the Pieces You Glued Together
glue some new waste pieces on or the already glued pieces to each other.
Step 4: Now You Have a Big Piece
make several of those and glue them to either a waste piece that won't be seen anymore or a basepiece that will be a big part of your bowl.
above you see bothe possibilities. For the pot with the plant I used a Base piece that wasnt quite big enougth by itselfe. I filled up the places where it was lacking volume
In order to glue stuff like that you need flat surfaces I use primarily the rasp for that If you have a Disksander and you hate that isnt used often enougth so its to sharp … use that.... also its sometimes hard to clamp, I don't know what to say about that, just be creative.
Step 5: Turning
weeeell just be cautious, please! I try not to trust the glue too much. For the plant thing I used a metal thing so the wood doesn´t come in contact with water ….
oh also I finished it with sandpaper obviously and lindseed oil... but I guess you can do whatever, If you don't constantly pour water all over.
Step 6: The End
If someone accually does that or is inspierd by that, let me know I reallly want to see If you use Instagramm tag me @astjaeger otherwise send me a message here or a commet, whatever... Email me if you want Astjaeger@gmail.com... send me nudes also and tell me about my nigarian unkle that died...
Gardening Contest
Gardening Contest
Be the First to Share
    • Puzzles Speed Challenge
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
    5 Discussions
    doing2much
    doing2much
    1 year ago
    What a gorgeous planter and I LOVE the idea of using up stuff that would otherwise go to waste! I'm wondering whether you should have saved this for the woodworking or thrash to treasure contest, though...
    Ham-made
    Ham-made
    1 year ago
    Great use of scraps!
    Cheers!
    Mr. Ham
    audreyobscura
    audreyobscura
    1 year ago
    Thanks for sharing your build!
    Astjaeger
    Astjaeger
    Reply 1 year ago
    no problemo
