Mosaic Tea Light
Introduction: Mosaic Tea Light
About: I am IT professional, living in Bangalore, India. As new gadgets come out everyday, we indulge in spending significant time and money on these gadgets. And our kids are learning from us, they know how to use...
Hi All,
This is a recycle glass bottle project where you can create beautiful mosaic tea lights for your home
I am using Olives glass jar, which I cut using a bottle cutter which I made few months back, link
https://www.instructables.com/id/Glass-Bottle-Cutt...
Step 1: What Do We Need ?
Material
  • Multi colored glass beads ( flat )
  • Glass jar
  • PVA glue or fevicol
  • Tooth pick
  • White cement
  • Tea Light candle
Step 2: Glass Beads
  • Clean the glass surface with soap and water, wipe it with a soft cloth and let it dry
  • I am using pva glue to stick the glass beads in place, I do not like hot glue
  • The pva glue can be removed and we can adjust beads we we want
  • I started with one line of blue beads at the bottom and one at the top
  • With green and red beads make design
  • Keep a watch on the position of beads, they tend to slip away, adjust them using the tooth picks
  • Use a fan to speed up drying process
  • Best results if we let it dry for 24 hours
Step 3: Cement
  • Once the pva glue has dried, it will become transparent, only then start with this step
  • Add 2 spoons of white cement to 1/2 spoon of water, mix well to form a paste
  • Apply cement paste to fill the gaps and make a even layer
  • Leave it for 15 minutes, then with moist cloth, wipe the glass beds clean
  • Apply more cement paste where needed and clean the glass beads
  • Let it dry for 24 hrs
Step 4: Finishing
  • Let the thing dry for 24 hrs
  • All the glass beads are clearing visible from inside
  • Since the glass beads are flat and glass jar is not, you may see some cement, do not worry about it
  • Apply a layer of clear coat or pva glue on cement to give a glossy look
  • Light a candle and place in the this and enjoy the it's beauty
Let me know your comments and suggestion, Since this was my first attempt, I kept the design simple
Creative Misuse Contest
Be the First to Share
    • Puzzles Speed Challenge
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
