Mosquito Net With Magnets for Van Window
1,431
12
About: Always tinkering, a few times successfully
I’m writing this Instructible to help van dwellers sleep with a breeze in summer while keeping the buggers away!
It's pretty simple but works wonders.
Materials needed:
- Mosquito netting, sold in ardware stores by the meter/yard or rolls (https://www.amazon.com/Gardeningwill-Mosquito-Barrier-Hunting-Netting/dp/B00MB8YH2Q/ref=sr_1_3?ie=UTF8&qid=1534509056&sr=8-3&keywords=mosquito+net+roll)
- Soldering iron. (If you don't have one, you may be able to do it heating a screwdiver head with a lighter)
- Neodimium Magnets 10 x 3 mm (https://www.amazon.com/dp/B0796FDYZ8/ref=twister_B077L2Y36K?_encoding=UTF8&th=1)
Step 1:
* Place moquito netting over the window and mark with permanent marker the location of the magnets, spaced by about 15 cm (6 in) from each other, and making sure each corner has one magnet.
* Cut netting around the marks, leaving an extra 3 cm (1 1/4 in)
I was going to sew the seams and the pockets for the magnets, but thought the soldering iron would do a much quicker job. As it turns out, I was right, but it took a bit of practice to get the temperature and pressure right. These will depend on how thick your netting is and it's composition. With a spare piece, practice until you get it right. In my case, it takes about twice the pressure as you would use with a writing pen, and about twice the speed of (my) hand writing.
RIght after you have passed the iron, press with your fingers to make a good seal.
* Using soldering iron, mark a pocket around each mark, leaving the pocket open at the top to insert the magnet.
* Continue with soldering iron to seam between each pocket
* Insert the magnets in the pockets, and do the final sealing with the iron. Magnets do what they do... so they will try to jump to the soldering iron, or viceversa, so you can hold the magnet down with a clip or clothespeg.
Step 2: Done!
Now you can leave your window open and sleep with a breeze.
I'm going to do the same for one of the back doors of the van, so that I can have an air current on hot summer nights.
Future improvement: Next line of defense in the form of a thermo-nuclear device tripped by detection of mosquito wing beating frequency
    • Faux-Real Contest
      Faux-Real Contest
    • Epilog X Contest
      Epilog X Contest
    • Warm and Fuzzy Contest
    3 Discussions
    Debiec68
    4 months ago
    I've had wads of old screen and even bought some new screen since my van had all the original screens ripped out of before I got it. But I've tried (and failed) at re-installing them. I so your AWESOME and idea is a good GODSEND. I so thanks, and I'm off to follow your instructable!
    owlsquest
    5 months ago
    Could have used something like this this summer as it is much faster install. Ended up duct taping screening to inside of driver/passenger van window frames, then used auto window buttons to lower window afterwards.
    From experience, make sure there are no gaps in screening and 'install' your screening about 30 minutes before sunset while outside temp is still warm. Little beggers make a bee-line for heat source - US!! First night it seemed like our van was a vacumn sucking them in until we put up screens early.
    Great instructible. Will make them over winter for next year. Gets a vote from me.
    perec3owlsquest
    Reply 5 months ago
    Thanks! I'll be glad if it helps you sleep better next summer. In my area, it is still need these warm evenings!
