Introduction: Mouse Trap Car
You will need...
-mouse trap
-a block of wood a little bigger than the mouse trap
-one foot string
-two small Lego wheel
-two big Lego wheels
-Lego axle.
-3 eyelets. -2 wood screws
-glue gun
-drill
Step 1: Mouse Block
Glue the mouse trap with the impact side closest to the end
Step 2: Eyelets
Then you screw two eyelets in the middle right and left sides spread apart. And screw the last eyelet in the middle top corner.
Step 3: Axle Wheels
Third you have to drill a hole through the Lego axle then put the axle throw the 2 eyelets put the one foot string through the eyelet in the top and through the axle and tie it also put the two big Lego wheels on the ends of each side of the axle.
Step 4: Small Wheels
You have to drill in the small Lego wheels in with the wood screws in the front.
Step 5: Impact Arm
Finally tie the other end of the string to the impact arm
Step 6: How to Use It
You pull back the arm and roll the back wheel the opposite way you want the car to go and set up the mouse trap hit the trigger and there you go. If it is not working out look through my directions again.
