Music Reactive LED | Dancing LED Circuit | Dancing LED | Simple Circuit
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today in this video tutorial i am going to show you Step By Step
How to make music reactive led circuit using transistor
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
❖ Please Subscribe / Like Facebook Page ❖
https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
https://www.facebook.com/Circuit-DIY-122206971927...
You Will Find Full Project Description and All Useful Material Including
• Circuit Diagram / Schematic
• Hardware / Component List
• Code
• Datasheet
• Pin Configuration Etc
Thanks for Watching It.
↪ For Any Difficulty Please Comment Below
Step 1: Useful Material
❖ Hardware Required ❖
► 9V Battery with Clip
► Breadboard
► Jumper Wires
► BC457 transistors x5
► 100nf ceremic capacitor
► LED x4
► 1K resistor x4
► 10K resistor x2
► 1M resistor
► Mic
❖ Circuit Diagram ❖
Link ► https://www.file-up.org/i40p2y60prxh
Step 2: Useful Steps
❖ Steps ❖
STEP # 1 ( Connect Transistors )
► Connect 5 BC457transistors anywhere on the breadboard
STEP # 2 ( Connect wires )
► Connect wire to the base pin of one transistor to the base pin of another do this for all four transistors.
STEP # 3 ( Connect LED )
► Connect +ve pin of each LED on the +ve rail and the negative pin on the collector pin of each connected transistors.
STEP # 4 ( Connect resistors )
► Connect 1K resistor to the emitter pin of each transistor to GND
STEP # 5 ( Connect transistor )
► Connect BC547 transistor on the board
► Connect wire BTW the collector pin to the base pin of previous connected transistors
► Connect wire BTW emitter pin and GND
STEP # 6 ( Connect resistor )
► Connect 10k resistor BTW the +ve rail and the collector pin of newly connected transistor
STEP # 7 ( Connect resistor and capacitor )
► Connect 1M ohm resistor BTW the base pin and +ve rail
► Conenct 10k ohm resistor with 100nf capacitor to the base pin of transistor
STEP # 8 ( Connect mic )
► Connect mic BTW base pin and GND
STEP # 9 ( testing )
► Connect battery and test
    • Faux-Real Contest
      Faux-Real Contest
    • Sweet Treats Challenge
    • Warm and Fuzzy Contest
