My Skateboard
My skateboard introduction: I through tinkercad website, using cylinder, cube and other connectors, through the establishment of models, to complete my skateboard design.
Teacher Notes
Step 1: Make the Radian Part of the Front and Back End of the Skateboard
First, use three transparent cubes to intercept a cylinder ,
and then cut the arc . Then connect the arc with the cuboid and make it.
Step 2: Assembly Connecting Slide
one half skateboard is connected by arc and cuboid, and the other half skateboard is copied to form a skateboard plane
Step 3: Mounting Connector
Install two bearings under the surface of the slide plate to hold the roller shaft in place.
Step 4: Complete Installation
Install a pulley on the pulley shaft to make a pulley.
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
