NE555 Timer | Configuring the NE555 Timer in an Astable Configuration
Introduction: NE555 Timer | Configuring the NE555 Timer in an Astable Configuration
The NE555 timer is one of the most commonly used ICs in the electronics world. It is in the form of DIP 8, meaning that it features 8 pins.
Teacher Notes
Step 1: View the Video!!!
See the video!
Step 2: Gather Your Materials
The materials list needed for this project is below:
1 x NE555 Timer
1 x 10 nF Non-Polarized Capacitor
1 x Breadboard
1 x Perfboard
1 x LED
1 x 470 K Ohm Resistor
1 x 1 K Ohm Resistor
1 x 220 Ohm Resistor (You can change this value dependant on how bright you want your LED to be)
1 x 1 Microfarad Electrolytic Capacitor
Jumper Cables
Power Source (5V)
Soldering Iron & Soldering Wire
Step 3: Learning the Workings of the IC | the Pinout
The image attached displays the pinout of the IC. This will help you follow the schematic.
Step 4: Circuit Schematic
To make any circuit, the schematic is essential. The circuit for this project is in the picture.
Step 5: Prototype the Circuit
There is a peculiar spectrum here. Some people like to make projects, and leave them on a breadboard. Others don't use a breadboard.
I always find that it is much easier to prototype a circuit first on a breadboard, rather than doing what many people do, start soldering immediately. The reason being is that it is much easier to correct mistakes on a breadboard than on a perfboard.
Simply connect the circuit as it's drawn on the schematic on the breadboard. I won't show how to use a breadboard in this tutorial, but if you don't know how to use one, please leave me a message, and I will write an instructable about it.
Step 6: Finalize the Project & Solder It!
Like I mentioned before, once you're done prototyping, you can now solder it to make it permanent.
Step 7: Final Comments
You're Done!
If you have any questions or concerns, please contact me at efficientsparks@engineer.com.
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    2 Discussions
    Great 555 Timer tutorial. These are great for beginning electronics projects. They are so versatile.
    Efficient Sparks
    Efficient Sparks
    Reply 1 year ago
    Thank you. I definately agree. They are indispensable ICs.
