NOT ANOTHER SHEETROCK REPAIR INSTRUCTABLE?
Introduction: NOT ANOTHER SHEETROCK REPAIR INSTRUCTABLE?
About: In my shop I have a name for hammer, saw, and plier. The saw is Tess, the hammer's Joe, and Glumdalclitch is the plier. Yes, I'm brillig, and my slithy toves still gyre and gimble in the wabe. With that, ...
YES, ANOTHER SHEETROCK REPAIR INSTRUCTABLE!
Step 1: SEE THE PRETTY HOLE
OH, YES, IT IS ANOTHER SHEETROCK REPAIR INSTRUCTABLE, BUT I'M GOING TO GO A LITTLE OLD SCHOOL ON YOU.
SEE THE PRETTY HOLE? IT NEEDS TO BE FIXED. FIX, KINK, FIX.
Step 2: SEE THE SHEETROCK?
I FOUND A PIECE OF SHEETROCK IN THE ATTIC.
NOW, HERE'S SOME OLD SCHOOLING FOR YOU. SHEETROCK OR WALL BOARD OR GYPSUM BOARD COMES IN DIFFERENT THICKNESSES. 1/4" 3/8" 1/2" 5/8"
1/4" IS USED FOR VARIOUS THINGS BUT ONE IS TO SKIN A DAMAGED WALL WITHOUT REPLACING ALL THE SHEETROCK UNDERNEATH. YES, IT IS LAMINATED TO THE EXISTING WALL.
3/8" USED TO BE FOR WALLS BUT HAS SINCE BEEN REPLACED WITH 1/2"
1/2" IS STANDARD FOR INTERIOR WALLS IN YOU HOUSE.
5/8" IS WHAT THEY CALL FIRE RETARDANT AND IS USUALLY FOUND IN GARAGES AMOUNG OTHER PLACES.
SHEETROCK ALSO COMES IN VARIOUS LENGTHS. USUALLY 4' WIDE AND 8' 10' 12' 16' LONG. YOU CAN ALSO BUY 2' X 2' CHUNKS AT THE BIG BOX STORES.
Step 3: WE NEED SPACKLE, KINK.
THIS IS ALSO CALLED JOINT COMPOUNT. I LIKE THE NAME SPACKLE. THIS IS NOT THE LIGHT WEIGHT, OR FAST DRYING, OR SPECIALTY STUFF. IT IS WHAT I USED FOR YEARS WHEN I DID HOME IMPROVEMENTS. BESIDES, THIS IS A HOME REPAIR AND I'M NOT IN ANY HURRY AND I DON'T NEED FAST DRYING STUFF. YES, IT COMES IN DIFFERENT TUB SIZES. I JUST HAPPEN TO HAVE THIS.
Step 4: TIDY UP, KINK
THIS OPENING WENT FROM STUD TO STUD. I NEATENED UP THE STUDS. THERE ARE WAYS TO ADD SUPPORTS TO A HOLE WHERE THE STUDS ARE ABSENT. I'LL GIEVE A BRIEF EXPLANATION LATER.
Step 5: MEASURE, KINK, MEASURE
THIS IS A GARAGE WITH 5/8" SHEETROCK. THE REPLACMENT PIECE IS 5/8" IF IT HAD BEEN ONLY 1/2" YOU CAN ADD THIN STRIP OF 1/8" WOOD TO THE STUDS. IF NO WOOD, THEN USE CARDBOARD.
MEASURE THE OPENING WIDTH AND HEIGHT IN SEVERAL PLACES AND JOT DOWN THE SMALLEST MEASUREMENTS. YOU DON'T WANT THE PATCH TO BE LARGER THAN THE OPENING.
Step 6: FASTENING TIPS AND a TIP FOR FASTENING
USE 1 1/4" SCREWS. PROFESSIONALS USE A SHEETROCK GUN WHICH HAS A STOP ON THE BIT TO PREVENT THE SCREW FROM BREAKING THE PAPER. IF YOU ARE GENTLE YOU CAN ACHIEVE THIS WITHOUT A SHEETROCK GUN. OR JUST BUY A SHEETROCK BIT. IT DOES THE SAME THING.
YOU WANT TO MAKE SURE THE SCREW IS DIMPLED JUST BELOW THE PAPER'S SURFACE SO THE SPACKLE WILL COVER IT AND IT DOESN'T PROTRUDE.
Step 7: WATCH KINK GO OLD SCHOOL. GO, KINK, GO.
MY JOINT COVERING OF CHOICE IS PAPAER TAPE AS OPPOSED TO JUST FILLING IN THE GAPS OR MESH TAPE OR STICKY TAPE OR ANY NEWFANGLED STUFF ON THE MARKET. YOU'RE DARN TOOTIN' I JUST USED THE WORD NEWFANGLED, YOU GOL DURN WHIPPERSNAPPERS. I TOLD YOU I WAS GOING OLD SCHOOL.
Step 8: CUT, KINK, CUT.
PAPER SIDE UP, SCORE A LINE WITH A UTILITY KNIFE JUST DEEP ENOUGH TO CUT THE FACE PAPAER. NO NEED TO CUT ALL THE WAY THROUGH THE SHEETROCK. JUST PICK IT UP, PLACE THE SCORED FACE AWAY FROM YOU, PUT YOUR KNEE BEHIND THE CUT AND PULL. THEN CUT ALONG THE INSIDE FOLD.
Step 9: WATCH KINK FIT THE PIECE IN THE HOLE
TEST FIT. IF IT FITS MOVE ON, IF NOT, SMOOTH OUT ANY PART THAT BLOCKS THE FIT. HERE I USED A PIECE OF SAND PAPER WRAPPED AROUND A BLOCK OF WOOD.
ALSO, SEE THAT WOOD IN THE SECOND PICTURE. THAT IS HOW YOU GIVE YOURSELF SOMETHING TO SCREW TO IF YOU DON'T HAVE STUDS. PLACE IT IN THE OPENING, SCREW IT IN TO THE EXISTING SHEETROCK AND USE IT TO SUPPORT THE PATCH.
THIS IS MY GARAGE AND I'M NOT GOING CRAZY WITH IT.
'SCUSE ME WHILE I SING A BIT OF PATSY CLINE: CRAZY. I'M CRAZY FOR BEING SO LONELY. I'M CRAZY FOR BEING SO BLUE......
Step 10: NICE FIT, KINK
SCREWS ARE USUALLY SPACE 8" APART AND DIMPLED BELOW THE SURFACE. TIME TO SCREW AROUND AND SECURE THE PIECE.
Step 11: LOOK AT ALL THE PRETTY SPACKLE KNIVES
I USE A SUCCESSION OF SPACKLE KNIVES. FIRST I START WITH A 6' KNIFE. I ALSO LIKE TO USE A HAWK (THAT FLAT TRAY I'M HOLDING) AS OPPOSED TO A TUB AS SHOWN IN THE LAST PICTURE.
Step 12: YUMMY
NO, NOT YUMMY. I TAKE THE SPACKLE AND SPREAD IT OUT AND LUMP IT TOGETHER AND SPREAD IT OUT GETTING OUT ANY LUMPS UNTIL IT IS CREAMY LIKE PEANUT BUTTER. THE SMOOTHER IT IS NOW THE BETTER YOUR FINISHED JOB WILL LOOK.
Step 13: TAP, TAP, TAP, WATCH KINK TAP
THE METAL HEAL OF THE SPACKLE KNIFE CAN BE USED TO HAMMER IN PROTRUDING NAILS OR DIMPLE BUMPS.
Step 14: SEE KINK HIDE THE SEAMS
MEASURE THE PAPER TAPE AND CUT IT BY HOLDING THE SPACKLE KNIFE AGAINST IT AND PULLING. FILL THE JOINT WITH SPACKLE AND SPREAD OUT ON EATHER SIDE WIDER THAN THE TAPE. LAY ON THE TAPE GENTLY AND EVEN MORE GENTLY EMBED IT WITH THE SPACKLE KNIFE. REPEATING--GENTLY. ONCE EMBEDDED SCRAPE OUT THE SPACKLE FROM UNDER THE TAPE. (OH, NO, KINK, TAKE IT OUT?) HOLD THE KNIFE AT ABOUT A 45 DEGREE ANGLE. CONTINUE UNTIL THE TAPE IS EMBEDDED AND THERE ARE ABSOLUTELY NO LUMPS OF SPACKLE ON THE WALL.
THIS IS THE BIGGEST MISTAKE I'VE SEEN PEOPLE DO. I RARELY SAND. I PUT ON THIN COATS, NOT THICK, AND KEEP IT SMOOTH.
YOU MIGHT THINK THIS IS NOT GOING TO COVER THE SEAM, BUT JUST YOU WAIT, HENRY HIGGINS, JUST YOU WAIT. WE ARE GOING TO REPEAT THIS PROCESS A FEW MORE TIMES.
Step 15: LOOK HOW NEAT KINK IS
TRY NOT TO GET SPACKLE ALL OVER YOUR TOOLS. WORK CLEAN, ESPECIALLY WORK WITH A CLEAN KNIFE.
Step 16: SEE HOW PATIENT KINK IS.
FIRST COAT AND IT IS SMOOTH AND I AM DONE FOR THE DAY. I LET IT DRY OVER NIGHT.
Step 17: SEE KINK YAWN, READY FOR ANOTHER DAY
THE NEXT DAY I ADD A SECOND COAT. AND THEN SCRAPE IT OFF. YES, KEEPING IT SMOOTH, NO LUMPS, BUMPS OR LINES. YOU MIGHT THINK SCRAPING IT OFF LEAVES YOU WHERE YOUR STARTED, BUT IT DOESN'T. YOU ARE ACTUALLY ADDING THIN COATS WITH EACH APPLICATION. AGAIN, NOTICE THE ANGLE AT WIHCH I HOLD THE SPACKLE KNIFE. THIS BOTH APPLIES SPACKLE AND SCRAPES OFF EXCESS.
Step 18: OH, NO KINK, NOT SPONGEBOB...
I AGAIN LET IT DRY OVER NIGHT AND THEN TAKE A WET SPONGE AND GO OVER THE WALL. THIS SMOOTHS OUT ANY MINOR IMPERFECTIONS.
Step 19: SEE THE PRETTY SPACKLE KNIVES
FOR THE FIRST APPLICATION I USE A 6" KNIFE, 8" FOR THE SECOND, AND 12" FOR THE THIRD. FOR ME, I'M DONE. THIS IS ACTUALLY PAINT-READY, BUT IT IS MY GARAGE AND I DON'T INTEND TO PAINT.
I HOPE MY OLD SCHOOL APPROACH WAS INFORMATIVE.
Step 20: THANK YOU, XENA, SAYS KINK
Step 21:
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    4 Discussions
    ghaines1
    ghaines1
    2 years ago
    If you have to constantly get in there to add more circuits, you might want to hang a painting or make a magnetic closed door that provides access. The second I took the time to do a nice repair the way you did is the minute I need to cut another hole. (I don't know if my comment is responsive, so please forgive me).
    Kink Jarfold
    Kink Jarfold
    Reply 2 years ago
    Your response was fine and I take no offense. I'm way too old and my skin is way too thick. Lemme 'splain this to you, Loosy. Wifey and I downsized and moved into this house last Halloween. It is our last house. It needed work and we got a good deal because I knew I could do the work having been in the business a number of years. That electrical cut out came with the property. We're not doing any wiring that would call for me to have to cut through my work, but even if I did I can fix it again. After all, it's a garage. Like Maggie said in Point Of No Return: I never did mind about the little things. But I agree with you on--As soon as you fix something you have to re-break it and start all over again.
    Thanks for taking the time to comment. It is truly appreciated.
    Kink
    Kink Jarfold
    Kink Jarfold
    Reply 2 years ago
    We all have things like this on our to do list. That's probably why there are s many sheetrock repair instructables out there.
