Namlem "Chin-cock" K'nex Assult Rifle.
Introduction: Namlem "Chin-cock" K'nex Assult Rifle.
This is an original gun, but it's based largely on Perfect Duck's Red impact. It's called the "Chin-cock" because you can cock it with your chin. You don't have to, it's just sort of a gimmick.
It's a poerfull, accurate gun with a trigger system that I'm pretty sure is new and original. I call it the "twist trigger."
Step 1: Barrel and Chamber
Ok, here's the barrel and the bullet chamber. You're going to need a lot of tan pieces, but if you're short, you might be able to manage if you just put one or two extra blue spacers in between each one. That isn't really recommended though.
Step 2: Hopper
the hopper is really simple. Sorry that I forgot to take a pic of the hopper without ammo.
Step 3: Ram, Spring, and Back Section
You're going to need a good spring that is about the length of a yellow rod, give or take a little.
Step 4: Firing Pin
Easy.
Step 5: Twist Trigger
here's the trigger-type thing. I call it a twist trigger.
Step 6: Final Steps
Now you just put the two parts together and then put the reinforcing parts on.
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    13 Discussions
    dynno97
    dynno97
    10 years ago on Introduction
    I will give it 4 stars cause it was one of the early guns
    why would you "cock" with your chin. because if you did you couldnt have much power out of it.
    Rage
    Rage
    12 years ago on Introduction
    interesting, however it is still a basic mechanism, without any realy fancy looks to it. non the less, great instructable.
    mmzdaniel
    mmzdaniel
    its nice... just to inform you all the gatlings on the site use this trigger...
    knexster
    knexster
    Looks cool, i dont understand the trigger though. Is the auto-load hopper style or is it like stacking rods in a perfect tower? Nice gun 8/10
    Namlem
    Namlem
    Reply 12 years ago on Introduction
    It's just a regular hopper. There is some width to it and the rods don't stack perfectly. The trigger is pretty simple and easy to figure out when you build it. You just push the back end of the trigger to the left, twisting it.
    smidge147
    smidge147
    that is so cheap!but still creative.OFFICIAL FIRST COMMENT fobble wobble ur dont count as theres no actual comment.!ha!first comment
