Introduction: Printing With Nature's Amazing 'Colour Bug'
About: Welcome! Pleased to meet you, I am Barb; a Maker. I have been making things AND explaining how to make things for as long as I can remember. I was all about DIY before it was a popular term. I absolutely love …
Yes, you read that right; it's a little bug that makes that amazing colour! Have you ever 'tasted the rainbow; of Skittles' - then you have already eaten some. Let me introduce you to the incredible colourful Cochineal!
It never ceases to amaze me what treasures that ‘Mother Nature' has up her sleeves!
In my recent obsession of eco dyeing and printing with natural materials on fabric I discovered even more wonderment! Combining some pre-dyeing with eco printing leads to a colour explosion. What you see here was permanently printed by nature; no hand or brush was involved...
Step 1: Make Your Dye
This tutorial is about Eco Printing; a method that uses nature's gifts to create permanent prints and also uses an all natural food-safe dye. If you have never heard about Eco Printing or want more info check my tutorial here.
On a recent trip to a small shop with all kinds of fibre and dyeing goodies I went berserk! I was on a mission to get some indigo but I found something else; some crazy small little bugs that give the most amazing gift of colour!
What you Need:
  • Fabric (silk works the easiest but other natural fibres can print)
  • Leaves (tannin rich like sumac, maple, rose, eucalyptus and more)
  • Cochineal (dried bugs)
  • mortar and pestal or coffee grinder
  • small pot
  • water
  • strainer, filter mesh
  • dowel or pipe
  • butcher's twine
  • cling wrap or plastic bag
  • large steaming pot
Cochineal is a female insect that grows on cactus in Mexico. It is known to give a huge amount of red colour called carmine for the small amount of matter. As little as 3% of the weight of fibre that you are dyeing can give good colour (calculate weight of material against weight of cochineal) 10-20% will give strong colour.
How to use Cochineal: The little dry carcasses (don’t worry, you can’t really see any arms and legs) can be ground up either in a mortar and pestle or a coffee grinder as this is a food safe colour anyway (I have heard some famous coffee company uses it for the pink colour). It grinds quite small so it can be used as is or strained out of the water. I have tried both methods with success. I use a scrap of organza as a fine mesh strainer similar to making tea.
Step 2: Dye the Silk
Once the dye water has been made I add my silk fabric or scarves to the pot and slowly bring it to a low simmer. You can dye any natural fibres but silk works the easiest. For more eco printing basics see here.
High heat can kill the colour so I bring it to a low simmer gradually. I hold the heat for about an hour and then let it sit and cool over night to set even more colour.
Put some gloves on a wring it out. Lovely strong pink! Note the dark specks? Those are the residue of ground cochineal. They may give some darker spots so you may want to strain the dye-water. I am not too concerned with perfect even colour.
Step 3: Bundling With the Leaves
The Bundling
I rely on my favourite leaves to print; sumac and maple. These were used fresh however dried can also work. As stated in the introduction you will need something to wrap the layers around. A pipe or piece of wood/rod can work, as long as it can be heated.
Step 4: Design With Leaves
Lay the silk flat and place the leaves. Many different leaves can print; it is a bit of experimentation. The fronts and back print differently so vary the pattern as you like. There are tannins in the leaves that will react to give colour.
Step 5: Adding a Mordant
The key is to have everything as smooth and flat as possible for defined prints.
Rather than soaking/dipping the leaves in an iron-water solution I use an 'iron blanket' here to help the reaction of the tannins and also as a mordant to make the prints permanent. Old cotton sheets ripped into strips are soaked in a weak rusty-iron-water and wrung out well. This way the iron comes into contact around the leaves rather than on them. It is then carefully laid over the leaves.
As a barrier to stop bleed-through a layer of plastic is placed above the iron blanket. (strips cut from plastic drop sheet plastic can be tailored to the right width) Flatten and smooth before rolling up tightly.
Step 6: All Tied Up
Once they are all rolled the bundles are then wrapped tightly with string and ready for the processing. The string will keep everything in contact.
Step 7: The Steaming
Be aware that this instruction shows how it has worked great for me however results may vary according to many factors. The iron-water strength, the leaves, the fabric, the water PH, all play some role in the final outcome. But that is what makes it interesting! It truly is magical and ONE OF A KIND!
The Eco Print Processing
I prefer to steam my bundles as then there is less water and also less darkening at the ends of the rolls. These have been steamed outside on a BBQ side burner in an aluminum lidded roaster. Make sure to check that the water does not disappear! I steam for about 2 hours. I can usually start to smell some odd aroma from the leaves ‘cooking’, hence I prefer exterior cooking.
When I unrolled my first Cochineal dyed piece I almost lost my mind with the amazing colours! am now hooked on Eco Printing. I can barely keep up with buying silk…
To allow a bit longer chance of picking up colour I sometimes place the steamed rolls in a blanket as they will hold the heat and ‘process’ even longer. Once cool they can be unrolled.
Go ahead… Do a ‘happy dance’! I am sure that I did! As an artist who has painted for so many years of my career this just astonished me so much. The variation of the pinks and purples and reds! I believe (no chemistry degree here) that it is all about the acid and alkali reacting with the dye. Many reds change according to acidity as seen with red cabbage. Cochineal however is not fugitive (meaning it washes out or fades) and has great lasting ability.
Step 8: Where the Magic Happens
To allow a bit longer chance of picking up colour I sometimes place the steamed rolls in a blanket as they will hold the heat and ‘process’ even longer. Once cool they can be unrolled. Go ahead… Do a ‘happy dance’! I am sure that I did! As an artist who has painted for so many years of my career this just astonished me so much. The variation of the pinks and purples and reds! I believe (no chemistry degree here) that it is all about the acid and alkali reacting with the dye. Many reds change according to acidity as seen with red cabbage. Cochineal however is not fugitive (meaning it washes out or fades) and has great lasting ability.
Compost the used leaves and wash the fabric in a PH neutral soap like 'Dawn'. Let it dry naturally.
Step 9: Admire Your Gift of Nature
Once dried and ironed you will not be able to stop looking at it. The range of reds and pinks to purples... awesome!
Do visit here for many more instructions for eco printing
Step 10: Wear Your Scarf
Oh, by the way, my apologies to the little cochineal fellows (actually it’s the females, figures)! 'Take comfort in the fact that your ‘colour’ shines on for many years to come and we will be in constant awe of your amazing abilities! Thank you!'
And thank you to my readers for joining me… and for more of my journey in the amazing world of Eco Printing see more here
If you love nature and unique projects I am willing to share with you here
Colors of the Rainbow Contest
