Introduction: Nebula Mason Jar
Meant for ages 12+. This project is meant to to mimic the look of nebulas (clouds of gas and dust found in space). CAUTION: This project requires the use of a plastic knife and mason jar, both of which can cause injuries if broken or used improperly.
Step 1: Materials
- 1 mason jar with lid (16oz or larger)
- cotton balls
- water
- pink glitter
- 1 oz bottle of navy blue paint
- 1 oz bottle of teal color paint
- 1 oz bottle of purple paint
- plastic knife
- styrofoam cup
Step 2:
Twist off the mason jar lid. Set aside.
Step 3:
Opening the water bottle, pour some water into thestyrofoam cup. Fill it up until it reaches the second line from the bottom of the cup.
Step 4:
Pour the water from the styrofoam cup into the Mason jar
Step 5:
Grab the navy blue paint and squeeze about four drops into the water or until you get the desired color you want. Then stir with the plastic knife until all the paint is dissolved.
Step 6:
Carefully pull apart one cotton ball so it resembles a cloud. Do the same with the rest so that there will be enough to absorb the water.
Step 7:
Add the cotton ball into the Mason jar and using the plastic knife, gently push the cotton ball to the bottom of the jar. Repeat until all water is absorbed.
Step 8:
Repeat step 2 and 3
Step 9:
Using the teal paint, squeeze about four drops into the water or until you get the desired color you want. Then carefully stir with the plastic knife until all the paint is dissolved.
Step 10:
Repeat step 5 and 6
Step 11:
Add a pinch of the pink glitter to the sides of the Mason jar, spreading it out with the plastic knife.
Step 12:
Using the plastic knife, poke down on the sides of the mason jar so the colors can blend together.
Step 13:
Repeat steps 2 and 3
Step 14:
Repeat step 8 but this time with the color purple.
Step 15:
Repeat steps 5 and 6
Step 16:
Repeat step 11
Step 17:
Repeat step 2 and 3
Step 18:
Repeat steps 4,5 and 6
Step 19:
Repeat steps 10 and 11
Step 20:
Replace the lid set aside earlier and tighten.
Step 21:
You now have your very own Nebula Mason jar. Enjoy!
