Neo Egg Timer
Introduction: Neo Egg Timer
About: Born in London in 1957. 1st job at age 16 was a TV engineer (valves !) Worked at a computer company repairing hardware (when 1k of ram was on a board the size of an A4 sheet of paper). Self taught in program...
I wanted to find a practical use for a NeoPixel ring.
I decided to make a boiled egg timer!
The NeoPixel rings are so easy to drive with an arduino and there are lots of very good examples on the web.
I modified the code from [NeoPixel Ring simple sketch (c) 2013 Shae Erisson]. Its a sketch which shows off what is possible with these rings.
Teacher Notes
Step 1: Hardware
This is such a simple project using very few components.
Parts list
Arduino Pro Mini ( although any Arduino will work)
24 led NeoPixel Ring
2 x Push to Make momentary switches (Green button for start - red for stop / reset)
1 x buzzer (any 5v buzzer you can get hold of)
1 x AA (x3 battery) holder with switch to give 4.5v (I also used this as the stand)
1 project box - I used an old vitamin pill container.
Holt melt glue gun or sticky stuff.
Connecting it up.....
Connect the green switch between Pin 2 & ground.
Connect the red switch between reset & ground.
Connect the NeoPixel ring to 5v supply & ground with the IN connected to pin 6
Step 2: The Software and Operation
Upload the sketch & switch on.
Initially the leds with chase Blue & Red.
Press the green switch to start the timer. This initiates the interrupt routine
attachInterrupt(0,startup,FALLING);
The bottom led shows green to indicate the timer has started.
Each led is set to show white at 7 second intervals.You may wish to change this!
7 seconds after the bottom green led turns white, the buzzer sounds intermittently and the leds chase white, red and blue until the red switch is pressed or the power is switched off.
Operation
Turn the timer on.
Place the room temperature eggs into boiling water.
Press the green button.
When alarm sounds, press red button
Removed perfectly cooked boiled eggs :-)
Switch off timer.
I could do with another Instrucables T Shirt, so please vote in the LEDs Contest
Thank You :-)
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Clocks Contest
      Clocks Contest
    DIY Hacks and How Tos
    Hello there!
    We're glad you want to share something with the Instructables community!
    And we’re here to help you out.
    Due to some recent changes on the site, we are no longer able to publish stand-alone videos and other forms of incomplete posts. In order to be published live on the site, Instructables must consist of the following things:
    - Multiple steps showing how you made your project
    - Written instructions in each step
    - Your own original images
    Beyond making your Instructable simply publishable, this guide (https://www.instructables.com/id/How-to-Create-a-Feature-Worthy-Instructable/) explains what is required to have your Instructables featured by our site editors. It’s very helpful, and definitely worth checking out.
    We would love to review your project again after you have made the necessary edits, and we will publish your project if it is eligible.
    If you have any questions, please feel free to ask right here or send us an email at service@instructables.com.
    Best,
    Instructables Community Manager
