Neopixel RGB LED 5-Color Cycler (Arduino)
About: Electrical Engineering Student & Hobbyist
This project is a ring of 12 RGB LEDs controlled to show different set colours (in a smile pattern), based on the resistance of the slide potentiometer.
If anyone has any suggestions, I'd be happy to read them as improvements can always be made. :)
Teacher Notes
Step 1: Bill of Materials (BOM)
Step 2: Wiring
Diagram was created with Circuito.io
(click the image to see full diagram)
Step 3: Arduino Code
The original code is an Adafruit Neopixel Example, "Simple," modified by myself to work with this project.
Currently it shows five different colours, either red, yellow, green, blue or violet. If the potentiometer is not in range of the values set into the conditional statements, it will turn all the LEDs off. (set R,G,B to 0,0,0).
First Time Author
First Time Author
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    2 Discussions
