New Year's Glasses
Introduction: New Year's Glasses
Simple modeling christmas glasses with SelfCAD
Teacher Notes
Step 1: Frame
Slide 1 .Use Drowing - Free Hand - Donut , create a circle like in the picture
Slide 2 . Use Circle - value erase , create a larger hole
Slide 3. Use Scale - set the value as on a slide
Step 2: Copy
Create the copy . Use Guides, measure 16mm and screw Frame
Step 3: Finish the Frame
Slide 1 Use Drowing - Free Hand - Text indicate the number and draw it
Slide 2 set objects as on a slide
Slide 3 Use Drowing - Free Hand - Text indicate theexclamation markand draw it
Slide 4 and 5 set objects as on slides
Step 4: We Complete the Creation of the Frame
Slide 1 Select all objects, use Stitch & Scoop - Union
Slide 2 Select object, use Magic Fix - Tolerance 214
Slide 3 Expand the object as on a slide, hide the object
Step 5: Glasses Temples
Slide 1 and 2 Use Reference image , choose a picture
Slide 3 Use Drawing - Free Hand set the value as on a slide and draw
Step 6: Glasses Temples
Slide 1 nad 2 Use Scale 2 times , Set the value as on a slide
Slide 3 Use Snap to put the glasses temples
Slide 4 Activate Magnet and choose a place
Slide 5 correct using a tool Move
Step 7: Create a Connection
Slide 1 Create Cube , set the value as on a slide
Side 2 Use Scale and Move to to achieve the result as on a slide (view mode Mesh + Wireframe )
Step 8: Mount
Slide 1 Select a frame use Magic Fix
Slide 2 Select frame and connector - use Stitch & Scoop use value as on a slide
Slide 3 you should get a small hole
Slide 4 Select frame and connector - useStitch & Scoop - Union
Slide 5 Result
Step 9: Make a Logo
Slide 1 Use Drowing Free - Hand - Text , draw text
Slide 2 set the object as on the picture using Move and Rotate. Use Stitch & Scoop - set the settings as on the slide
Slide 3 result
Slide 4 do the same with the second glasse temple
Step 10: Magic Fix
Slide 1 Select glasse temple and use Magic Fix
slide 2 result
1 Person Made This Project!
  • Magnets Challenge
    Magnets Challenge
  • Snow Challenge
    Snow Challenge
  • Wearables Contest
    Wearables Contest
