Night Lamp Made by the Old Tape Cassettes
Hello guys......
Here I had made a Night lampusing the old tape cassettes.
This Lamp is very Easy to make..
I hope you like it.
Follow us on ...
YouTube - https://www.youtube.com/channel/UCBBRzYNzCALewaf20rg6dWg?view_as=subscriber
Facebook - https://www.facebook.com/kedar1705/
Teacher Notes
Step 1: Tools and Requirements
Requirements -
  1. 12 V LED s * 2
  2. Zip Ties * As required
  3. 12 V DC Adapter * 1
  4. Tape cassettes * 36
  5. 12 V female pin * 1
  6. Strong cable with two wires * As required
Tools -
  1. Wire Cutter & skipper
  2. electrical wire / insulating wire
Expect to the cassettes all other tools & requirements you will get in Hardware & Electronics store.
And all these will get you at cheaper price in stores than online...
So I would suggest to buy from stores...
SO LET'S START........!
Step 2: Step to Build the Walls of Lamp
Actually this lamp is cubic shaped...
So first we have to make walls of the cube using tape cassettes...
Use lamp walls using 6 cassettes and assemble casets by zip ties...
make 6 cassettes walls....
Step 3: Building the Cassettes Cube
Now build the CUBE using the CASSETTE WALLS WHICH WE MADE...
Build the cube as shown in Images given above...
Step 4: Connecting & Mounting the LED S
STEPS -
  1. First remove some LED wire insulation cover.
  2. Then mount them inside the cube of cassettes.
  3. Connect the wires in the parallel connection.
  4. Take the wire cable.
  5. Insert the cable in the corner of cube as shown.
  6. Zip the zip ties to wire as shown to hold the cable in the cube.
  7. Connect cable terminals to the terminals of LED s.
  8. Cut the excess part of zip ties.
Step 5: The Power Supply
Connect the 12 V female pin to the another end of black cable...
And connect the 12 V adapter to the female pin...
Step 6: See This Project on Youtube
Step 7:
Reuse Contest
This is an entry in the
Reuse Contest
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    2 Discussions
    mr-kdsaudreyobscura
    Reply 17 days ago
    No, I hadn't.
    But I will try it soon...
    Thanks for your feedback & suggestion.
