Night Light
Introduction: Night Light
this project is fun and easy,just need little few step.it's a night light,when you sleeping you may activated it.it could automatically change the color.
But before make this project,you need to purchase arduino https://www.arduino.cc/en/Main/Software ,here is a link to purchase it.
Supplies:
12x15mm LED (any color)
some wires
Tissue
resistor
scissor
Empty shoe box ×1(or the box)
Arduino Leonardo ×1
Breadboard×1
wire cutter(it's up to you)
Teacher Notes
Step 1: Set Up a Wire and Led
first of all you need to set up your wire and led
blue wire connect to pin 13
yellow wire connect to pin 12
green wire connect to pin 11
caution:make sure you dig a hole on the box,to let the type A able to connect with arduino,You can use wire cutter If you need it,to let the wire looks not messy(it's up to you)
Make sure you set led and resistor into right place.
Step 2: Set a Tissue
set a tissue on the gate of shoe box,you need tape to stable it,otherwise it's unable to create a ''special visual effect'',when you set up and tissue and turn off the light in the room the night light should be beautiful.
Step 3: Code
https://create.arduino.cc/editor/Hunterlin/0a9fceb...
You can change the time or add more led (more pin)
all it's up to you
if you wants to customized it you can download arduino, just visit this website to download ,https://www.arduino.cc/en/main/software
Step 4: Finish!!!
Grand veiling!simple,right?this stuff also able to connect with power bank,just use A type connect with it,and it works.you can make more vivid if you need to,but don't make it too messy,which means don't set too many led ,because it just for night light.this project is fun and very extremely simple,hope you guys can enjoy it!
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
