No More Chaos - Spice Drawer Organizer
4,584
58
9
Introduction: No More Chaos - Spice Drawer Organizer
About: Mostly harmless
In general my home looks quite tidy and decluttered...
- BUT DON'T OPEN ANY DRAWERS OR CABINETS - theres only chaos waiting!
here's how I (finally ) organized my spice drawer (at least one drawer is chaos free now whohoo! ) !
Now I will have so many minutes more to write instructables instead of searching for cayenne pepper, thyme or even cinnamon! - GREAT! - a new way of living :)
I dedicate this instructable to everyone who is terrified about somones else open your (kitchen ) drawer -this one is for you!
Yes, I know you can buy these drawer inserts - but they are made from plastic which i kind of dislike and honestly: where's the fun?
- make it - don't buy it!
Step 1: Materials and Tools Needed
*I had this looooong ~1,5 m / 59" tube of cardboard lying around - it came with a carped :)
It should be around 5 cm/ 1,97" in diameter, if you use cardboard, you can widen it easily later.
in general you could use any kind of tubing - maybe an old pvc pipe, or even paper towel rolls taped together - so many possibilities and I'd love to see what you come up with!
*a glue gun, or tape, both works fine ( YES, I know that's basically plastic and I feel kinda bad about it )
*a sharp knife
*a measuring tape
* a pen and scissors (if you use tape )
I. Optional (but will add a certain amount of prettiness) :
*wrapping paper, or old book pages, pages from a cooking magazine - whatever you like
*white glue
*paintbrush - to spread the white glue
II. Optional (but makes it a little easier to clean - if you're into that part) :
*self adhesive clear vinyl ( YES! I know that's plastic too, but I had it already, so the damage was done already...)
Step 2: Emptying the Chaotic Spice Drawer and Measure
Now roll up your sleeves and get started!
get all these spice jars, odd refills, and dead bodies (empty jars ) out of the drawer - you will be surprised, how many stuff this drawer was able to hold - and you'll find a lot of crazy spice samples you collected to try someday ...
clean out all the loose powders that were the result of half (hearted ) closed jars and refill bags (and the samples )
*aaaaaaawwwww so fresh and so clean (clean ) *
and measure your drawer in length and width.
Step 3: Cut the Correct Length
I measured, that my tube was enough for (almost) 4 shorter tubes that would fit in my drawer,
the 4. tube would be a little shorter - but that's nothing to care about - it won't matter!
Cut the tubes, so that they fit exactly- maybe even with a little pressure.
A sharp carpet cutter was perfect for the job on this heavy cardboard tubing.
Step 4: Cut in Half Lengthwise
mark the tubes exact or approximate half - it's up to your eyeballing skills
then cut along the marked line - for my heavy tubing the wavy egde knife of my leatherman was great, I guess a jigsaw would work too, but the day I made it, it was -20°C / -4°F below and I dind't feel like working outside, brrrrrrrrrr
Now you have beautiful, inaccurate half tubes :)
Step 5: If It Doesn't Fit: Use Sheer Force!
If it doesn't fit your spice jars, give up instantly OR make it fit - you're a maker, aren't you!
in my case the cardboard tubing was unnecassarily strong, so I could simply tear alot of the inside layers and discard them, then, with a little ellbow grease, i pressed it wider with my hands against a hard surface.
Tadaaaaah! It fits perfectly :)
Step 6: Glue It!
place your - superb fitting - half tubes upside down on a non stick surface (I used a sheet of parchment paper )
align them and glue with hot glue or tape - both works fine!
It doesn't have to be pretty - but of course add some glitter if it makes you feel better :)
Step 7: Done ...
... if you want to keep it simple and like the industrial look and functionality.
proceed the instructable if you want to make it "a little more appealing"
- just in case -one beautiful day- someone else opens that drawer...
Step 8: I. Optional: Make It Pretty
now all the optional stuff and a big portion of customizing kicks in,
I used old book pages that I had left from another project - oddly shaped, that was time consuming - but I'm happy with the end result, and thats what counts :)
I glued everyting with white glue and trimmed the edges.
You may use:
wrapping paper,
newspaper
or maybe simply paint it
Step 9: II. Optional - Make It Last
Of course you want your hard work to last - even a cleaning attack of your mother in law - so it's time to make it more sturdy:
cut the self adhesive clear vinyl to the approximate size of the (now so pretty ) organizer
carefully cover the organizer and follow the round form with your hands - it's a little tricky, but quite forgiving.
trim the edges and you are almost done...
Note: you could also paint it with some coats of clear varnish instead.
Step 10: Organize a Little More...
time to get rid of all the odd samples, refills and other stuff.
use empty spice jars and label them correct
ohh that feeling - you finally get your act together!
Step 11: Be Proud!
it's ok to shed some tears of glory,
be proud, be thrilled, you made it! - one drawer closer to heaven ... ( erm, you know what I mean)
The craziest thing about this, every single jar and refill from the chaotic mess before, fitted into the new organizer - I didn't hide anything for the photos.
Now imagine you - confidently- ask someone else standing in your kitchen:
"could you please open that spice drawer and hand me that (super fancy) wasabi - sesame blend" ohhh such a great feeling! ( but pray for the person to open the right drawer and not the still chaotic one :D)
I hope you enjoyed your stay!
Mimikry
Organization Contest
Be the First to Share
    • Puzzles Speed Challenge
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
    9 Discussions
    seamster
    seamster
    1 year ago
    I like the way you made the little troughs! I've been wanting to make some kind of homemade case to store all of my sewing thread spools, and this is a perfect idea to incorporate . . if I ever get around to that project! ; )
    Mimikry
    Mimikry
    Reply 1 year ago
    I guess it would work great with thread spools as well!
    thanks for your comment :)
    OculumForamen
    OculumForamen
    1 year ago
    Great idea, Now I know how I'm going to make cutlery organizers for my cutlery drawer! No store bought organizers in my price range fit my drawers. I'm cheap, because I live on a limited income, so I love DIY projects like this! Thanks so much for the idea!!!
    Mimikry
    Mimikry
    Reply 1 year ago
    you're welcome :)
    home made pretty much always beats store bought - the difference feels in the wallet as well :)
    OutofPatience
    OutofPatience
    1 year ago
    Cute, clever, and useful...and easily achievable...what's not to like? Thanks!
    So far I have only used a lazy susan to organize my spice bottles. The space is limited but it does perform its job well which is to support easy retrieval.
    Mimikry
    Mimikry
    Reply 1 year ago
    I prefer everything hidden in drawers or behind doors - so I can keep my evil, chaotic side in secret ;) - At least the spice drawer is tidy now - well I guess this is me growing up ( still fighting it :D )
    A wall mounted Lazy susan would be cool though...
    hiwakoo
    hiwakoo
    1 year ago
    That is just what I needed. Thanks for sharing
    Mimikry
    Mimikry
    Reply 1 year ago
    you're welcome :)
    please share a picture when your done!
