No-Sew Fleece Cocoon-Blanket
3,794
44
10
Introduction: No-Sew Fleece Cocoon-Blanket
We’re right in the middle of winter, and a warm fleece blanket is always a good idea to have around the house. But don’t you just want to crawl into it to feel cozy?
With this cocoon-blanket you can! And it’s a no-sew pattern, so it’s easy and fast to do.
Teacher Notes
Step 1: Supplies
  • 2 fleece fabrics - 2 yards of each (different patterns recommended)
  • Scissors
  • Ruler
  • Flat surface (floor is the best option for cutting, due to the size of the fabrics)
Optional, but highly recommended:
  • Rotary cutter
  • Something to protect the surface you’re working on (I’m using this self-healing cutting mat, but even a flat cardboard box helps too)
  • Sewing clips, clothespins, or binder clips
Additional Notes:
  • Fabrics are normally 60 inches wide.
  • Your end product will be 3 to 5 inches smaller than the original fabric.
Step 2: Before Cutting
Most fleece fabrics have a “right side” and a “wrong side”. You want to make sure you assemble your blanket with the right side outwards. Meaning you will have the two "wrong sides" facing each other inside the cocoon.
There are several ways to identify fleece sides:
  1. Ask the fabric's store clerk to help you identify the correct side.
  2. Compare both sides of your fabric. If it has distinct patterns, you'll notice a difference on the details. The "wrong side" will have a smoother texture and faded colors, the "right side" will be brighter, and kind of lumpy and nubbly. In other patterns, the differences can be very subtle.
Step 3: Assemble Your Cocoon
1. Lay the two fabrics, one on top of the other, on the flat surface of your choosing. Remember, wrong sides facing each other.
2. Make sure your two pieces of fabric are exactly the same size. My helper assisted with this part.
a. Smooth the fabrics together, making sure that the one underneath is not wrinkled. Fleece is a thick fabric, so it makes it easier to see if there’s lumps or wrinkles in the bottom one.
b. Identify which one is bigger than the other. In my case, the top (patterned) fabric was bigger by a couple of inches. I arranged the fabrics together by one end (top end) and cut them the same size.
c. When cutting the pieces, make sure you also cut the selvage of the fabric (fancy word for the finished edge).
d. I used the rotary cutter and the self-healing pad to make this step easier; this can also be done with scissors. I also used the clips to keep the fabrics together.
Step 4: Setting Up the Cocoon-Blanket
To make the cocoon-blanket, we will tie together the fabric with fringes on 3 sides of the blankets.
1. Select the side that will be the opening of the cocoon.
2. Cut a 5x5 square on the bottom two corners (opposite of the chosen opening).
Step 5: Making the Fringes
1. Use the ruler and scissors to cut 1 inch wide and 5 inches long fringes through one side of the fabrics (I usually start with the bottom one to help secure the two fabrics in place).
* I use my self-healing mat as a ruler too.
* Fringes don’t have to be perfect, but as even as possible.
2. You can start tying up to secure the fabrics together. I wanted to bring some of the back color to the front, so I twisted the fringe in a way that the back color faces the front (see video).
*You can do other types of knots to give it the style you like.
3. You can start tying knots as you cut...or cut fringes through a side and then tie them.
* I usually secure the cocoon tying every 5 fringes, and later move to a more comfortable place to finish tying.
4. Continue making fringes along the three sides of your fabric. Leaving the "opening" untouched.
Step 6: Enjoy!
Once the three sides are tied together, your cocoon-blanket is ready to be used!
Enjoy the coziness and warmth, I know my helper is!
Warm and Fuzzy Challenge
Runner Up in the
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    10 Discussions
    jessyratfink
    jessyratfink
    12 days ago
    This is such a fabulous and easy idea! I need several of these for me and my cats :D
    CreatingMind
    CreatingMind
    Reply 12 days ago
    Mine loved it!
    NikkiE15
    NikkiE15
    Question 18 days ago
    Have you ever finished the top edge at all? I was thinking of trying satin binding.
    CreatingMind
    CreatingMind
    Answer 16 days ago
    I have closed the top to make a blanket instead of a cocoon. But some binding might be an nice upgrade to the cocoon. Some sewing might be required, thought. Let me know if you make it!
    JennEsau
    JennEsau
    4 weeks ago
    I’m going to have to make me one. I know my kids would want one as well. Thanks for sharing
    CreatingMind
    CreatingMind
    Reply 24 days ago
    Even the kids can even participate in the making of their own cocoons! They can tie the knots in their own way.
    creaky
    creaky
    4 weeks ago
    I need to make this but I think I'll tie all the sides to have a nice warm blanket to cover my legs as I sit on my chair. What a great idea to have a non sew blanket!
    CreatingMind
    CreatingMind
    Reply 4 weeks ago
    You can certainly tie all the sides. Just cut a 5x5 inch square on all corners. Enjoy!
    seamster
    seamster
    4 weeks ago
    Looks perfectly cozy! : )
    CreatingMind
    CreatingMind
    Reply 4 weeks ago
    Thanks! It is VERY cozy! We have two of these around our house.
