NodeMCU RGB LED | for Beginners
About: I am Sarful , I am a Mechatronics Engineer & also a teacher in Rajshahi Polytechnics Institute I am Interested in the evolution of technology in the automation industry , and i aspire to teach this techn...
In this Tutorial i will show you what is RGB Led and how it is work An RGB LED is a combination of 3 LEDs RED, GREEN and BLUE. These three colors Red, green and blue can make any color. By varying supplied voltage to RGB LEDs different colors are formed.
An RGB LED has 4 pin interfaces. 3 Pins are for Red, Blue and Green. There is a common pins for all three LEDsAn RGB LED can be two types-Common Anode:-Anode (+) pin is common.Common Cathode:- (Cathode-/GND) pin is common.
Hardware required
  1. NodeMCU
  2. Breadboard
  3. RGB LED
  4. Resistor 1k
  5. Jumper Male to male
Teacher Notes
Step 1: Schematic of Circuit
Step 2: Layout of Circuit
Step 3: Programming:
// Mechatronicslabrpi.blogspot.com Tutorial
// Hardware: NodeMCU
int RED = 5;
int GREEN = 4;
int BLUE = 0;
void setup() {
pinMode(RED, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(BLUE, OUTPUT);
void loop() {
digitalWrite(RED,HIGH);
digitalWrite(GREEN,LOW);
digitalWrite(BLUE,LOW);
delay (1000);
digitalWrite(RED,LOW);
digitalWrite(GREEN,HIGH);
delay (1000);
digitalWrite(BLUE,HIGH);
delay (1000);
Free download full file click here
Step 4: Video
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
