Most skateboards do not have a good anti-skid effect, which causes people to fall down when skateboarding, and damage to the skateboard when they fall. But this skateboard effectively solves this problem.
Supplies:
1. Hard wood for length/width/height80cm/20cm/1cm
2.Sheave 8 bearings 8 big gears
3.Screw sly, connect tube several.
Teacher Notes
Step 1: Step1:build the Base Board
1.The base plate consists of a 60cmx 20cmx 1cm straight board and two slightly tilted curve panels
2.Align and group it to form the shape shown
Step 2: Step2:make Rollers
1.Take two sheaves together with connectors, combine eight into four groups.
2. Finally, the shape is formed as shown.
Step 3: Step3:connect the Roller and Motherboard
1.Combine it with a large gear and a small pressure-reducing unit similar to the front and rear wheels of a motorcycle, which is then combined into a device as shown, and then seamlessly weldwith with a fine welding device
2. Finally get the device as shown
Step 4: Step4:check If It Is Done
1. Experiment on its feasibility
2. Last end
