Obstacle Avoidance Game With Distance Sensor
Introduction: Obstacle Avoidance Game With Distance Sensor
About: DIY electronics, javascript, IoT, obniz, programming, raspberrypi, arduino
Obstacle avoidance game like Flappy Bird. Move your hand to avoid the collision. It is easy to make and fun to play!
Teacher Notes
Step 1: Things Used in This Project
obniz
IR distance sensor
Smartphone or computer
Step 2: Setting Up Obniz
To set up obniz, all you need to do is to follow three steps.
  1. Connect obniz to wifi.
  2. Connect devices like LED or motors to obniz .
  3. Scan QR code of obniz and start programming. You do not need to install any software.
Step 3:
Connect obniz and the distance sensor as below.
  • io0 : Signal(yellow)
  • io1 : GND(black)
  • io2 : VCC(red)
Step 4:
We use HTML5 canvas.
<canvas id="field" width="300" height="300"/>
let canvas = document.getElementById('field');
let ctx = canvas.getContext('2d');
Set value of distance sensor to var "inputHeight", and use it anytime.
let inputHeight = 0;
let obniz = new Obniz("OBNIZ_ID_HERE"); obniz.onconnect = async function () { let sensor = obniz.wired("GP2Y0A21YK0F", {vcc: 2, gnd: 1, signal: 0}); sensor.start(function (height) { inputHeight = height; }) };
{vcc: 2, gnd: 1, signal: 0} should be changed if you connect devices different from Step 2.
This value is used as each frame input.
let input = (300 - inputHeight);
input = Math.min(Math.max(0, input), canvas.height); dot.push(input);
Step 5: Program
Please get the program from here
Game Life Contest
Game Life Contest
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Clocks Contest
      Clocks Contest
