Old Bathtub to New
Introduction: Old Bathtub to New
When your bathtub gets old and nasty you have a few options to fix it. However it’s usally expensive. Put in a new one, have someone come re-glaze it, or you could buy a expensive re-glaze kit and do it your self, or my way that will cost you about $20.
Step 1: Getting Started
You need to decide if your going to take the tub out or leave it in. This can be messy so I took mine out and did it out side. If you leave it in you need to tap off enything you don’t want paint on and always make sure you have proper ventilation.
Step 2: Things You Will Need
90% of being successful is preparation the tub needs to be clean and I mean super clean. You will need.
A putty knife
SOS scrubber
220 sandpaper
Mineral spirits
T.S.P ( trisodium phosphate)
Rags
Rubber cleaning gloves
Krylon appliance spray paint any color you want (Ichose white)
Step 3: Cleaning the Tub
Like I said 90% of being successful is peeping the tub for paint.
1. Use the putty knife and scrape off any caulk, soppe scum, or hard water, don’t gouge at the tub.
2. After everything is removed take a clean rag and wipe down the tub with mineral spirits. Let it dry.
3. When the tub is dry lightly sand down everywhere you’re going to paint with 220 sandpaper.
4. Wipe with mineral spirits in a clean rag it a second time.
5. Using the SOS pad, TSP, gloves and water wash and rinse the tub. Let it dry completely.
Step 4: Painting the Tub
Using the Krylon appliance paint you will need 3 or 4 cans of paint. Paint several thin layers on to the tub waiting 30 minutes at least in between layer. The thin layers ensure the paint dries correctly, I did about five coats of paint. Once you have all of your coats of paint on let the tub dry floor at a minimum of 24 hours before reinstalling or using the tub.
I have used this method in my own home and in several rental houses. so far I’ve had no problems with the durability but like I said 90% of this project is making sure the tub is prepared correctly.
Trash to Treasure
Trash to Treasure
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    • Metalworking Contest
    6 Discussions
    Peterthinking
    Peterthinking
    1 year ago
    Was this a metal tub or fiberglass one?
    B1withduck
    B1withduck
    Reply 1 year ago
    This one was PVC but I have also done this on fiberglass and metal tubs.
    PeacefulDreamer60
    PeacefulDreamer60
    1 year ago
    Wow look at how awesome the Bathtub looks. Great job and great instructions.
    Makerneer
    Makerneer
    1 year ago
    That looks way easier than a re-glaze!
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    I think the tub turned out great :)
    B1withduck
    B1withduck
    Reply 1 year ago
    Thanks
