Origami Ballistic Barrier Paper Model
About: The BYU Compliant Mechanisms Research Group (CMR) involves students and faculty who strive to make an impact by creating compliant mechanism theories and applications that are novel, used by others, and make...
Would you believe that origami can stop bullets? The origami above does just that!
Why origami?
· Allows barrier to quickly deploy to complex shape
· Allows barrier to be compactly stored
· Allows for barrier to be manufactured flat
· For more advantages of origami in engineering, see our website: cmr.byu.edu
This Instructable will help you create your own paper barrier.
In the real barrier, the panels needed to be made of thick bullet-proof material so a variety of thick-folding techniques were used. For more information on the design, see this publication:
Seymour, Kenny, et al. "Origami-Based Deployable Ballistic Barrier." Proceedings of the 7th International Meeting on Origami in Science, Mathematics and Education, 2018.
Supplies:
Printer
Scissors
Barrier Pattern
Teacher Notes
Step 1: Print
Print or copy the fold pattern onto a piece of paper. The base pattern is a modified Yoshimura crease pattern.
Step 2: Cut Out
Cut along the bolded outer edges of the square pattern.
Step 3: Crease the Pattern
Follow the guidelines on the sheet. All the dashed lines are folded one direction, all the solid lines are folded the other direction.
Step 4: Collapse the Pattern
Collapse each layer of the pattern from the top to the bottom. The edges should rotate inward as the pattern folds flat.
Be the First to Share
    • Made with Math Contest
    • Cardboard Speed Challenge
    • Multi-Discipline Contest
