Origami Lily
Introduction: Origami Lily
This is a simple way to create an origami lily
Supplies:
Origami Paper or Regular Paper
Ruler
Scissors
Teacher Notes
Step 1: Start With a Square Piece of Paper
If you are using a regular piece of paper, then create an 8x8 square using the ruler and scissors.
Step 2: Fold the Top Corner to the Bottom Corner, Crease the Center
To help crease the paper better, you can use either your fingernail or the ruler
Step 3: Fold the Left Corner to the Right Corner, Creasing the Center
Step 4: Open the Top Layer and Squash It Down Will Creasing the Sides
Step 5: Turn the Paper Over and Squash the Flap Down
This time the paper will be on the left side and you will squash it down like you did on the other side. This creates a diamond.
Step 6: Lift Up the Upper Layer of the Right Side, Open It Up, and Squash It Down
After you do this on the one side, continue to do it on the other three sides.
Step 7: Rotate the Diamond Upside Down
Step 8: Fold the Figure in Half
Take the bottom corner and fold it up to top corner and then unfold it
Step 9: Fold the Upper and Left and Right Edges to the Center and Then Unfold It
Step 10: Squash Fold the Pocket
Pull down the pocket at the middle and crease the sides, this will create another smaller diamond and you will fold the pointy little flap up
Step 11: Squash the Three Other Pockets and Fold the Little Flaps Up
Step 12: Fold the Upper Layer of the Left Flap to the Right to Get a Blank Side
Step 13: Fold the Lower Left and Right Edges to the Center
Repeat this for all three sides
Step 14: Fold the Petals Down
You can also use a pencil to curl it but it's not necessary
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
