Origami Rose Ferrero Rocher Gift-Favors
Introduction: Origami Rose Ferrero Rocher Gift-Favors
About: Charlotte designs textiles and prints for a living. When she has a spot of free time, she often sneaks off to do something crafty with her hands. Enjoys making beautiful things and writing lists. Loves organ...
When I was in my teens, I was fascinated with origami and I loved flowers. So naturally I learnt how to fold paper into flowers. Plus, Japanese paper folding was cool. Soon I learnt the tedious Kawasaki Rose, and when Valentines' day rolled around, I discovered a very cool use for these origami roses:) These Origami Roses made from A4 sized square paper were the perfect size to hold 1 single Ferrero Rocher. To my delight, all my friends were fascinated by them and loved the novelty.
So, today, I'll share my secret with you... Who knows, it might already be widely known.... Do let me know, hahaha! I'm often impervious to these things -_-III
Step 1: Materials
1. A4 Paper, have fun with the colors
2. Ferrero Rocher
3. Your hands
4. A spot of time
Step 2: Prepping the Paper
Start with an A4 paper
Fold one corner diagonally down across to get a big square
Fold the rectangle where the square ends
Cut off the rectangle
You should have 1 big square and 1 long rectangle
Step 3: Pre-Creasing #1
Fold the square into half and unfold
Turn it around and repeat
You should get a big cross down the middle
Next, fold the bottom to match the middle line
Fold the top to match the middle line, unfold both
Turn it around, repeat for this side too
You should get a 4x4 grid
Step 4: Pre-Creasing #2
Fold down a triangle in the 4 corner squares of the paper
Fold the bottom up to match the second line from the top, unfold
Repeat for all 4 sides
Turn the paper to the other side, hiding the triangle folds from sight
Pinch the middle line and fold it up to the line right above the middle
Crease only the 2 middle squares
Fold it the other direction and crease the 2 squares on the other side
Unfold and repeat for the other side
You should have created a mini tick tac toe grid in the middle
Step 5: Pre-Creasing #3
Fold the left side of the paper to meet the right and crease to form a small diagonal line
Unfold
Fold the right side of the paper to meet the left side and crease to form a small diagonal line
Unfold
You should have a created a small V in the top 2nd and 3rd square at the top of the paper
Repeat for the 4 sides
When you turn the paper, all the Vs should be on your right hand side
Step 6: Pre-Creasing #4
Turn the paper around hiding the corner triangle folds form view
Fold the left side of the paper across to the right side creating a crease across the middle top 4 squares
Unfold
Step 7: Pre-Creasing #5
Locate the small V you made previously
Next to it on the right hand bottom corner should be and inverted triangle
Fold it up to create a horizontal line across
Unfold
Repeat for all the sides
Step 8: Pre-Creasing #7 LAST!!!
Place the square so it looks like a diamond
Fold the bottom to the top creating a diagonal fold
Unfold
Repeat for the other side
Fold the bottom up to the point of the top triangle fold
Crease only the left side to the middle point
Unfold
Repeat for all sides
You should have something resembling a windmill
You have now completed all the Pre-creasing!!!
Congratulations!!!
Step 9: Folding #1
Begin folding on the side where you can see the triangle folds
Place it on the diamond
Pinch up all the diagonal lines
Flatten the small square table in the middle and push the straight line down in the middle
The folded square in the middle should have caused two flaps to appears on each side
Push one to the right and one to the left
Fold down the top flap on both side and flatten it out
Step 10: Folding #2
Turn it to the other side where the are 4 folds converging in the middle
Where the flap is towards the right side, put your middle and ring finger under it and your thumb between the fold on top
Using your middle and ring finger, rush/pop the flap up to form an L shape block, 2 squares wide and 3 square long
Do the same for all sides
You should have a windmill form that sits
Step 11: Folding #3
Locate the small V at the base of the end of the windmill, it should be on the short side
Pinch the V to the left side to form a small triangle, hold that and turn to the other side of the paper
Fold the triangle back up
It is okay of a bit of it unravels, you just need to give the paper a bit of memory and to shape it
Step 12: Folding #4
(I've marked the tip of the triangle so you can see better here)
Next locate the trapezium next to the triangle
Fold it along the diagonal crease line so it forms the base of the trapezium
Make sure the trapezium is under the flap on the left
Fold the base inner corner of said flap inwards so that it forms a tiny triangle that hugs the trapezium
Do the same for all the 4 sides
Step 13: Folding #5
You might need to use all your fingers for this, alternatively, you can use paper clips to hold the foots in place
when you are folding the 4 sides, the paper should start curling into itself
use your hand to cup it for a better hold
You should have 4 pointy foots now
Step 14: Folding #6
Fold down each of the pointy foots along the vertical side of the right angle triangle and should have what looks like how you would fold your average carton box
Tuck the last one under the first one and your rose origami is complete
This is the base
The top looks like a spiral
Step 15: Folding #7 LAST!!!
Now it's time to shape the petals of your rose
Start by gently folding out the small outer petals, you will not need to crease anything as they will hold itself
Do the same for all 4 sides
Then start to gently fold down the big petals that converge into the center
Your need to do this delicately as too much force will tear the petals at the corners
Do the same for all the 4 big petals
Finally you have completed the origami kawasaki rose!!!
Step 16: Filling It With Chocolate!!!
Open up the base of the rose and put in the Ferrero Rocher
Fold the rose box close again
Your are done!!!
Step 17: Experimenting With the Paper
You can try different types of colored paper or kinds of paper
If you use a diagonally blocked paper, you will get this effect
If you pick out the lines on the pink paper, They are the edges of the petals, so you can mark them before hand
Try other patterns of paper, customize them to suit your event or theme
Step 18: My Experimentations!!!
I wanted to see how different they can be, so i used a myriad of different colors and textures of paper, pens to draw them
I wanted to see if I could create luxurious looking ones, so I gold-foiled them, nasty things gold foil... Get them all over my fingers...
But the overall effect looks good and they match the Gold foil of the Ferrero Rocher!!!
Step 19: Final Product
So, give them a try, watch people'reaction as they discover the tasty little morsels inside them. They make for a great surprise and talking point, I guarantee it.
Party Challenge
Runner Up in the
Party Challenge
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    8 Discussions
    offseid
    offseid
    1 year ago
    As Tye Rannosaurus said: It is very difficult to give paper folding directions online. You did a great job and used your photos very well! Good project too! :)
    SpiderOnTheWeb
    SpiderOnTheWeb
    Reply 1 year ago
    Thank you! I try to make sure that I can easily understand it too as I often have to repeatedly read instructions when trying new origami myself!
    Tye Rannosaurus
    Tye Rannosaurus
    1 year ago
    Origami has always stumped me, partially because most times the instructions are so hopelessly confusing...but your instructables is so clearly written and so beautifully photo documented and illustrated that I think even I might be able to pull this off. Really well written!
    SpiderOnTheWeb
    SpiderOnTheWeb
    Reply 1 year ago
    Thank you for your feedback and compliment, really appreciate it! If at any point you get stuck, feel free to drop a comment so i can help make things clearer!
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    These look good! I like the experiments you've done with the design :)
    attosa
    attosa
    1 year ago
    What a nice way to hold something super yummy :)
