Oriole Bird Feeder
About: I'm an independent lady who enjoys designing and completing new projects inside and outside my home. Quite satisfying to re use/ recycle and re purpose 'on the cheap' and realize a finished project that star...
Orioles are an extremely beautiful and colourful bird that graces us with their presence in early spring, sometimes throughout the summer and then again in the fall when they gather to migrate
If you're a birdwatcher it's always exciting to catch a glimpse of this timid brightly coloured orange bird
If you'd like to encourage orioles to visit your yard consider making an oriole feeder
Orioles are attracted to the colour 'orange' and absolutely 'luv' grape jelly and oranges
So I decided to construct a feeder that would satisfy their cravings
This was my goal when i decided to draw up plans and build my own oriole feeder
Supplies:
supplies needed:
- 3/8 in plywood (small scraps may work)
- length of 3/8" wood dowel (approx 21" long or 4 pc of 5 " each)
- 1 inch x 1 inch pieces of wood (approx 32" long and cut into specific sizes)
- 2 nails (2.25 inch long) and a hammer
- staple gun with staples (I used 3/8" staples)
- wood glue
- 2 plastic fruit cups (dole / generic fruit cups)
- orange paint (I used acrylic craft paint) and a small craft paint brush
- 20 g wire (approx 4.5 in)
Teacher Notes
Step 1: Cutting Out Pieces of Feeder
using 3/8" plywood cut to size the following pieces:
2 pc of 5 in x 6.5 in
1 pc of 4.25 in x 6.25 in
2 pc of triangles 5 in long and 2 in height (cut at a 45 degree angle from centre to corner)
using 1" x 1" length cut to size the following pieces:
2 pc of 8 in long
2 pc of 4 in long
2 pc of 2.75 in long
using the 3/8" wooden dowel cut to size the following pieces:
4 pc of 5 in long (tapering one end of each piece at a 45 degree angle)
Step 2: Assembling Base of Feeder
beginning with the 1" x 1" pieces of wood (already cut to size in previous step)
on a flat surface...
lay the first piece of 8" horizontally in front of you
next put one of each of the 4" pieces vertically on either end
then place the 2 pieces of 2.75" vertically in the centre
finally place th second piece of 8" horizontally along the top of your vertical pieces
this will make the bottom of the feeder (rectangle shape with 2 centre vertical pieces) and hold a plastic fruit cup on either side of the bottom framework
Once you have this layed out place a fruit cup in either side to confirm the placing is the correct size
The lip of the fruit cup should fit over the edge of the framework thus holding the fruitcup from falling through
(also allows you to easily remove them to clean and refill)
Measure twice then glue and staple the pieces together
Set this framework aside to dry (you may want to clamp it together until it dries)
Step 3: Constructing the Centre Support and Roof of Feeder
pick up the pc of 3/8' plywood that is cut to 6.25" x 4.25"
This will be the centre support of the feeder
** Using the hammer drive a nail into the centre of each flat side of the piece (do not drive nail through the wood...only to the point where it doesn't come through)
These nails will hold fruit such as half and orange (fruit side out) or an apple, plum etc
Set the centre support pc vertically in the middle of the bottom framework (after bottom is dry) centered in between the two 2.75" pieces
glue and staple the centre support to the bottom framework
Next locate the 2 triangle pieces of wood
These will be the front and back rafter to hold the roof
place the long edge of each triangle at the front and back edge of the centre support and glue and staple together
Set the two roof pieces lining up with the front and back rafter and glue and staple
pls note: the roof will / should overhang slightly to keep the rain away from oriole treats
Using pieces of dowel, place one dowel on each corner with the 45 degree angle lined up with the roof and flat end lined up in the centre of the corner of edges
These corner supports will give the feeder extra strength
After completed (glueing and stapling) I used a wood clamp to hold it all together leaving it on overnight to completely dry
Step 4: Attaching
Next paint the feeder inside and out
Set aside to dry (about 1 hour)
Confirm your new feeder is completely dry
Locate a suitable spot for your new oriole feeder
Orioles like to perch in tree tops so feeder should be visible and out in the open
Use a shepherd hook and place a distance away from other feeders (orioles are somewhat shy)
Fill one of the cups with grape jelly /water mixture (1 : 1) and the other with other treats...bing cherries, peas, purple grapes etc
Cut an orange in half and press it onto one of the nails fruit side facing outward
* pls remember to clean / change the grape jelly mixture at least every third day to keep it fresh
Step 5: Be Patient...the Birds Will Find Your Feeder (hopefully)
orioles may take a while to find your new feeder
especially if they're flying through during their migration
In the meantime you may also see woodpeckers and some other birds enjoying the treats you're offering
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
