PC Hardware Monitor With Arduino and ST7920 LCD
There are 2 versions of the project:
  • 4 numeric fieds and 1 graph for CPU load or clock
  • 4 independent graphs for CPU temperature, load, clock and used RAM
Parts:
  • Arduino Nano or Arduino Pro Mini with USB to serial adapter
  • ST7920 128x64 LCD
Supplies:
Parts:
Arduino + ST7920
Teacher Notes
Step 1: Connections
There are only 6 wires necessary to connect Arduino and ST7920 LCD in SPI mode.
Full list of connections from LCD side:
  • #01 GND to GND
  • #02 VCC to VCC (5V)
  • #04 RS to D10/CS or any pin
  • #05 R/W to D11/MOSI
  • #06 E to D13/SCK
  • #15 PSB to GND (for SPI mode)
  • #19 BLA to VCC, D9 or any pin via 300ohm resistor
  • #20 BLK to GND
To avoid extra GND lines solder 2 wires directly on LCD PCB: GND to PSB to BLK
Step 2: Arduino Firmware
Step 3: PC Software
  1. Download and install HardwareSerialMonitor
    https://cdn.hackaday.io/files/19018813666112/Hardw...
  2. Start it with administrator rights
  3. Choose correct serial port
Step 4: Demo Video:
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
