PCR Kayak Cart
This project is about building a cart that is able to transport a Kayak from your car to the river and back. Additionally, it is easy to disassemble to be able to fit into anyone's car/truck. This one is specifically designed for a 10ft long Kayak and 30in. width but can also reasonably fit a kayak with similar measurements.
By: Tom H, Kieran V, Michael S, and Bradley J.
Teacher Notes
Step 1: Getting Materials
3 PVC Pipe (2 10ftx1in pipes, 1 34inx1in pipe)
2 Bike tires (26in tires)
Metal Axis(36in in length)
15 T PVC Connectors ( 1in diameter)
2 L PVC Connectors (1in diameter)
1 + PVC Connector (1in diameter)
1 Straight PVC Connector (1in diameter)
2 1/2in Axle Nut
Blue PVC cement
Spray Paint (Can be any color you choose)
Kayak Measurements: 30in in width,10ft in Length
Step 2: Cutting the Pieces of PVC Pipe
Step 1: Cut PVC into 4, 10in pieces.
Step 2: Cut PVC into 8, 7in pieces out of the same 10 ft PVC Pipe.
Step 3: Cut PVC into 4, 4 1/6in pieces
Step 4: Cut PVC into 4, 6 in pieces
Step 5: Cut PVC into 8, 7 1/4in pieces
Step 6: Cut PVC into 2, 4 5/8in pieces
Step 7: Cut PVC into 2, 24in pieces
Step 8: Cut PVC into 1, 12in piece
Step 3: Adding Rope Holes
Step 1: Take all of the 10 in PVC cuts and drill a 3/8 hole 2in from the top
(this is to allow a rope to wrap around the kayak to keep it firmly in place)
Step 4: Connecting the PVC Pipes Part 1
Step 1: Take two of the 10in pieces and put a T PVC connector on each end.
Step 2: Connect in a rectangular shape with 4 of the 7in pieces.
Step 3: The middle will be connected with two 4 1/6in pieces with a T PVC connector connecting those in the middle.
Step 4: connect two 6in pieces to the bottom T PVC connector, then attach a T PVC connector to the end of those.
Step 5: Attach four of the 7 1/4in pieces to each end of the T PVC Connector.
Step 6: Attach the two 4 5/8in pieces to each end of the T PVC connector on the top.
(Look at the picture to better understand the direction of all the pieces)
[MAKE SURE TO GLUE ALL PIECES TOGETHER AND HAVE THEM TIGHT TOGETHER]
Step 5: Connecting the Pieces Part 2
Step 1: Take two 10in cuts and put on L connector on top of each, then on the other end and a T connector on each.
Step 2: Take 4 7in pieces connect them in a rectangular shape.(Use the + PVC connector on the top middle and a T connector on the bottom middle)
Step 3: Connect the middle with 2 of the 4 1/6in pieces and a T PVC Connector
Step 4: Take 2 of the 6in pieces and attach them to the bottom of the two T PVC connectors, then put a T piece on the end of each.
Step 5: Attach 4 of the 7 1/4in pieces to each end of the T PVC Connector.
Step 6: Add the 12in piece to the top of the + PVC connector (This will be the stand once it is complete)
Step 6: Connecting the PartsTogether
Step 1: Face the two sides to where the T holes are lined up.
Step 2: Glue a 24in piece into each side.
Step 3: Connect the two 24in pieces with the straight PVC connector piece.
Step 7: Adding the Wheels
Step 1: Put the metal axis through the top of Part One
Step 2: Attach a wheel to each end
Step 3: Hammer a cap on each end of the axis to secure the wheels on it
Step 8: Painting the Kayak Cart (Optional)
Step 1: Apply the spray paint in even amounts among the entire cart.
Step 2: Allow at least 24 hours for the paint to dry.
(Paint can be any color of your choosing, we just happened to choose black)
Step 9: Final Look
This is what the final Project should look like when it is complete.
Be the First to Share
    • Made with Math Contest
    • Cardboard Speed Challenge
    • Multi-Discipline Contest
