Introduction: PURE SINE WAVE INVERTER WITH LED AND LCD
The inverter PCB is easy to assemble by following the label of the components to be inserted. The choice of the voltage to be used to power the inverter ranging from 12v to 48v depends on kva you are designing. for any setup, a 12v relay is to be use.
The featuring M.C.U are the Microchip PIC16F72A OR PIC16F876A FEATURES OF THE ABOVE SCHEMATIC ARE STATED BELOW :
INVERTER PROTECTION : LOW-BATTERY SHUTDOWN
: OVER LOAD SHUTDOWN INPUT
: O/P SHORT CCT SHUT-DOWN INPUT
: HIGH TEMPERATURE SHUT-DOWN INPUT
: LOW-BATTERY : BEEP START AT 11 V
:INVERTER SHUT DOWN AT 10.5 V
:10 SEC DELAY BEFORE CHARGING
: AUTOMATIC VOLTAGE REGULATOR [INPUT: 180 V - 240 V] [OUTPUT: 211 V - 232 V]
INVERTER MONITOR : 16*2 LCD DISPLAY
: LED INDICATORS
: ERROR LED
: BUZZER
Step 1: Design and Transfer the Pcb Design
Step 2: Place and Solder Your Component
Step 3: Design Your H-bridge Board
Step 4: Testing With a 300w Transformer
Step 5: Finishing
DOWNLOAD LINKS:TOP SIDE: http://www.4shared.com/office/6lJrLprOba/ALL2__1_.htmlCOPPER SIDE : http://www.4shared.com/office/7-TQyIhvba/ALL3.htmlLCD ONLY: http://www.4shared.com/office/GHEuw6Huce/LCD_ONLY_6_3.htmlVIDEO: https://www.youtube.com/watch?v=sCzSu1rOE-4If you have any question, feel free to comment on this post.... ace circuit OR call me on+2348134573457 , +2348123206299Reference documents:PIC16F876A datasheet: ww1.microchip.com/downloads/en/devicedoc/39582b.pdf
