PVC LED STAND LAMP
About: B-tech second year student of electronic and communication engineering. I am working on research and patent drafting fields. I love to make anything related to electronics. Now, also i am working on solar pa...
It is PVC led light for study and also use as table lamp. 360 adjustable lamp. very easy to adjust this lamp. low cost making lamp for different purpose. Now follow the step carefully and built it easily. after making hit the like button, share the image and follow me.
Teacher Notes
Step 1: PVC PIPE REQUIREMENT
1. PVC PIPE - 12 INCH (1 PIECE)
2. PVC PIPE - 2 INCH (4 PIECES)
3. PVC 'L' JOINT - (2 PIECES)
4. PVC <150 DEGREE JOINT - (2 PIECES)
5. PVC 'T' JOINT- (1 PIECE)
6. PVC CAP -(2 PIECES)
Step 2: LED AND NUT BOLTS REQUIREMENT
1. led plates
2. nut bolt (1 piece)
3. sleeves pipe for nut bolt
Step 3: Cut the Pipe and Fit the Nut Bolts
1. Take a two inch one piece pipe and cut half (see it image how to cut the pipe)
2. Drill a whole for fitting the nut.
3. And put the sleeves in bolt for adjusting the nut bolts.
4. next step "2 inch cut pipe" put in the <105 degree pvc pipe.
Step 4: Assembling All the Part
1. All the joints and PVC straight pipe use and assemble it.
2. Do not use any glue gum and fevi-quick.
3. Simply use all the pipes and assemble it. after assembling put the whole in the back side.
4. now pass the wire in the pipe upper to lower down through whole then assemble it.
Step 5: INSTALL THE LED LIGHT IN PVC
1. Put the led in the cutting PVC and fix the bolt back side of led through the quick fix.
2. Then put the nut and tight it.
3. Fix the wiring then put the top of the stand.
4. check all the joints properly assembled.
5. Led lamp is ready for glow.
6. provide the 6 volts dc source with mobile phone charger or any device that can provide 6 volts dc source.
7. Lamp is working great.
Step 6: Final Review of Led Lamp
1. Adjust according to you choice.
2. PVC is adjustable.
3. TRY TO MAKE IT
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Multi-Discipline Contest
